I have a massive gap(5mm) between chassis mount and suspension rubber mount?
The passager side has a little 1-2mm gap but the drivers side is more then double the gap.
What is normal?
thanks
What is normal?
thanks
111 BHP@6,300 - 121 Ib-ft@2,500 - 3,200 from a 1400 SR with modified C14SE head, weber 32/34 on varijet inlet manifold, magnex 2" bore S/S exhaust system! Woohoo
I spotted this on mine today, been told its fine
lets the shock top/leg move and twist, think thats why..
thats i dont know,
its normal, they both should be the same on each side, thinner nut goes on the top.
nothing specail,not nylocks are anything, just normal nuts, just a thicker nut goes under the top disc and a thinner one goes ontop, the thicker one underneath gives the clearence needed to pivot freely,
