Swapping rev counters (Mk3 Cav)
Results 1 to 4 of 4
Thread: Swapping rev counters (Mk3 Cav)
    Joy
    Joy is offline
    Sep 2001
    Devon
    2WD Cav Turbo
    I need to fit an 8,000rpm rev counter in place of my 7k one in the Cav T. I`ve got an 8k one in a spare set of 160 clocks, can I just swap the rev counter round (not the whole clocks) or will it read incorrectly ?
    Cheers
    3.0 V6 Mk3 Cav - Saab B308I, F28, Speedlines, Wilwoods
    Cav 16v Turbo - T34, water inj, 26psi, F28, LSD, Speedlines
    04 Monaro 5.7 CV8 - Pedders Suspension, Wortec Catback
    Joy
    Joy is offline
    Sep 2001
    Devon
    2WD Cav Turbo
    BTT
    Mar 2001
    Torquay
    LC 20VT
    Just swap the speedo to the right binnacle you want to use
    (easier,from memory,than the rev counter)
    should still read correct.
    Joy
    Joy is offline
    Sep 2001
    Devon
    2WD Cav Turbo
    Cheers Lee, I`ve just swapped to speedos as the two revs counters I have are of different designs & wouldn`t interchange.
