Intermittent ABS light
Results 1 to 5 of 5
Thread: Intermittent ABS light
    Eastern Regional Coordinator MarkW's Avatar
    Nov 2003
    Essex
    Astra Convertible
    Hi all, I have an intermittent ABS fault (light comes on) normally when the engine has been idling or in slow moving traffic for a while.
    Most times, if I switch off, wait a while and switch the engine back on, the light goes out, but it's getting worse, so I know the problem isn't just a gremlin.
    What I was wondering is this:
    Is there anyway I can disable the ABS (fuse removal?) until I can afford to get it fixed properly?
    And will it effect brake performance?
    Thanks
    Roofless.........
    Mig Events 2012
    Gagged
    Apr 2007
    Essex
    Astra Saloon TD
    If you pull the fuse, the only difference you'll feel is that the pedal wont start jumping around under anything more than light braking like it does with the ABS engaged. Be careful on damp stuff if you do disable it, I found out why... RIP My old SRi =] ... Anyhoo... Why don't you flash the codes out of it? That would tell you what the problem is... Might only be a small sensor or something...
    stu
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    On some cars if you pull the ABS fuse you also lose your brake lights - check this before going for a drive.
    Nottingham near Ikea
    Vectra ST200 #0005
    On a Cally you can remove the ABS fuse and your brakes won't be effected but obviously the ABS won't work and the light will be perminantely lit on the dash. It's probably one of the sensor pickups that dirty so try reading the codes off first to find the offending sensor and give both the sensor and the ABS ring a good clean.
    Nov 2003
    Essex
    Astra Convertible
    Super dooper, thanks guys.
    Roofless.........
    Mig Events 2012
