my cav turbo has the 2 white guages (oil and volts) from a cally T in the centre console, does anyone know how to wire these up? cheers![]()
www.vauxsausage.com - the place for all your vauxhall buying/selling needs
Volts is dead easy, ignition live (black) and earth (brown)
the oil gauge... would that be pressure or temperature? im not too familliar with the callys.... or cavs for that matter![]()
I would imagine the oil pressure one would need to be connected to a pressure sender but not the std one? It just reads 'on' or 'off' AFAIK.
Have a look around to see if you can find where the calibra turbo one is on the engine and compare to your engine. (Assuming its not a CLET engine...)
Melv - "you shouldn't be allowed boobs that size as your only a wee lassie"
