Rite need sum help with lower arm bushesrite been changing the suspension on my bro
Results 1 to 8 of 8
Thread: Rite need sum help with lower arm bushesrite been changing the suspension on my bro
    Oct 2006
    houghton
    Nova star (89)
    rite been changing the suspension on my bro in laws astra and we decided to change the lower arm bushes to the polyutherine ones. i tried to cut then out, tried to use a hammer and a bit of gentle persuasion lol but still it didnt work, now av ****ed one of them. i rounded the head off so the bolt doesnt slide through it cleanly, it bites the bush and instead of moving freely now it has a bit of spring in it. so we now deffo need to change the bushes cos we dont trust the ones that are in. so if anyone has any ideas then it wud be much appreciated cheers
    **edit** now has punctuation **edit**
    Nov 2003
    Folkestone , kent
    2003 Astra SRi
    Can you use some punctuation and then i'll read it and give you an answer.
    Ta
    Rob
    Sep 2004
    Nottingham M1 J26
    911. Loves: Dirty sluts.
    Agreed. I'll read it when it is readable.
    It hurts my brain just looking at it
    Dec 2005
    Solihull, W.Midlands
    118d,G1.8SE2,C1
    blowtorch and melt the ****er out.
    Selling - PC and lots of meg's cleaning stuff, random z18(xe / xer) and z16(xe / xep) parts.
    Feb 2002
    Co. Kerry, Ireland
    2.0 Nova, Astra Mk3
    I've beaten them out with a large hammer before now. There's no point beating around the bush and giving it a bit of "gentle persuasion". If you haven't got a big vice or a press, it's got to be one of those occasions where all hell breaks loose and you just beat it hard repeatedly, until the needle on the Schitzometre hits force 10 and you start talking/screaming in a language that no one has ever heard before.
    Try and find something the same diametre as the outer edge of the bush and beat it out with that. Make sure the wishbone is well supported underneath so you don't bend it.
    MIGWeb User sounds2k's Avatar
    May 2006
    Queenborough, Kent
    Saab 9000 Aero
    ... don't you normally need a hydraulic press and require about 3 or 4 tons of pressure?
    so getting the replacements back in again would require a similar amount, I'd have thought beating the c**p out of it with a hammer wouldn't get even close - at least not without destroying the wishbone ...
    Feb 2002
    Co. Kerry, Ireland
    2.0 Nova, Astra Mk3
    I polybushed the front of my Astra last Summer. I ended up beating the old bushes out with a big lump hammer and a couple of nicely sized/positioned bits and pieces of metal. If you didn't support the wishbone properly, you could easily damage it with the hammer. I used a big vice last few times I did bushes on Astras/Cavs (it was out of order when I was polybushing the Astra lol). The polybushes are a lot easier to fit than standard bushes. The rear bush needs a bit of pressure to squeeze it in, but you can fit all the polybushes using your bare hands.
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    Penetrating oil, and try and find something the same diameter as the bush to help it out.
    This is how we did my land rover bushes, and they'd been in there for 30 years.
