tuning a 2.0 8v 20seh
Results 1 to 22 of 22
Thread: tuning a 2.0 8v 20seh
    May 2006
    omagh, N. ireland
    hey guys im rebuldin my 20seh in teh next few weeks n wonderin wot mods would work well on it. how woul dthese mods suit it n wot else do u think i shuld do:
    fast road cam
    higher compression
    lighten flywheel
    chip??
    ne other ideas guy??
    Aug 2004
    Lincoln
    2004 Corsa SRi CDTi
    port, polish and gas flow the head. but if you have that done make sure the place you take it has a flow bench!
    May 2006
    omagh, N. ireland
    would that give good gains? i already have a 4branch so take it would work well with it
    Dec 2005
    UK
    Frontera LWB, Astra GSI
    Quote Originally Posted by keggy View Post
    fast road cam
    higher compression
    lighten flywheel
    chip??
    They sound like very sensible mods!
    As Matt says, a port and a polish would help it breathe a bit easier, and maybe some more free flowing manifolds would just finish the job off nicely.
    May 2006
    omagh, N. ireland
    for the flywheel shul di just get 1 skimmed r would i be better wid buying 1? ne other ideas on mods
    Dec 2001
    Braintree, Essex
    Mk3 Astra
    fast road cam
    higher compression
    lighten flywheel
    chip??
    Stock head flows enough air for 140-145hp with a cam that has 0.500" lift or more at the valve. Porting it is a waste of time in my experience if your keeping the stock intake and especially the stock, flap type, airflow meter - these are the real restriction.
    If you have to keep the stock intake manifold I'd hunt out a Mk3 Astra SRi. These had a 2L 8v engine. The injection system on that came with a air mass meter (same type as the 2.5 V6 just smaller in bore). These flow more air than the older flap type airflow meter. Use the complete engine loom and ECU with the AMM and fit to your engine.
    Then you can use your mods above. A aluminium underdrive pulley from TTV racing would also help, as well as the usual K&N (with cold air feed) + straight through 2.25-2.5" exhaust.
    If you buy a exhaust manifold, speak to the exhaust manufacturer and tell them your cam specs i.e timing events (IVO, IVC, etc.). They may adjust the primary lengths to suit your cam for better scavenging.
    Glasgow
    saab turbo
    oh alloy pulleys? much? and website at all?
    curiosity killed the cat...................but for a while i was a suspect!!
    May 2006
    omagh, N. ireland
    so i can just swap over teh inlet manifold of a mk3 2.0 8v astra? how would the ecu caffect the running of teh engine comparred to the ecu i got in now?
    Dec 2005
    walsall
    corsa c20let
    you wont have the plug for the amm and you cant just wire it up because the ecu wont except it. the only way is too have the ecu and wireing off the astra sri, the running will be the same because your not changing anything else as long as the wireing is done right.
    May 2006
    omagh, N. ireland
    ok thanks so wot astra is it in astra g?
    Regional Co-ordinator nige-p's Avatar
    Jan 2005
    Moreton, Wirral, United
    saab astra mk3
    was about to start some mods on mine and was gonna get rid of the inlet system what gains could be had from putting bike carbs on because webers and throttle bodies are well to expensive dont want to turbo just want some raw power
    Apr 2005
    near glasgow
    nova 2.0t 8v soon :)
    If your talking SEH get the head done, 150hp+ is possible with no other mods! Quite expensive tho
    Jan 2005
    saab astra mk3
    i will get that done then and get the exaust size matched to the ports how much is it to get the head done? my dads mate does it so will get them to do it just after a rough price
    Jun 2005
    Powys in Mid Wales
    300TDi Discovery
    Regarding the mk3 astra bits, which btw was fitted with the lower bhp c20ne engine, I can't see how you can use the loom and ecu etc off the c20ne and fit it to a 20seh as they're different engines internally and have different compression ratio's as you'll know
    Managing Director - Severn Developments Ltd
    May 2006
    omagh, N. ireland
    Quote Originally Posted by rhydgte View Post
    thats wot ive been wondering aswell?? it is bound to be differently mapped? maybe this mod and a remap would be the way to go
    Apr 2005
    near glasgow
    i got bigger inlet valves, ported, skimmed and cleaned for 450 iirc
    MIGClub Member Blackie's Avatar
    Nov 2005
    Ballyclare N.Ireland
    '94 Corsa SRi
    I'm glad I read this, I'm gettin a 2l engine on wednesday and I believe its the 20seh and want to tune it before I throw it into the space currently occupied by the c18ne donkey thats in my cavvy
    Dec 2001
    Braintree, Essex
    Mk3 Astra
    Quote Originally Posted by Ghost_Walker View Post
    http://www.ttvracing.com/
    Contact them. They can do a custom pulley to your requirements too, i.e. underdrive power steering pump but with stock alternator ratio.
    Dec 2001
    Braintree, Essex
    Mk3 Astra
    Yes you can use the loom and ecu. A 0.8 increase in compression ratio and slightly revised cam timing events doesn't make for a completely different engine internally!
    If you get an "off the shelf" chip it still won't be optimally tuned for your modifications. The only way to tune the stock ecu properly is to remove the stock chip, attach a laptop running a emulator then live map it on the dyno. Once that is done a proper chip can be burned with the new map and installed into the ecu.
    Jun 2005
    Powys in Mid Wales
    300TDi Discovery
    Quote Originally Posted by Stefan View Post
    Yes ok, but I still can't see how using an ecu off a 115bhp engine will do anything for a 130bhp engine, I mean, will it even work??
    P.S Pistons are different too
    lakeside, essex
    corsa gsi show car
    20seh engine with c20ne injection etc
    i had a mark 3 astra sri which was supposed to have the c20ne engine , the previous owner removed it and put a 20seh engine from a cavalier sri130 into it, it worked well, i had it for over 2 years and never had a problem with it. i would definitely recommend it.
    Sep 2003
    Johannesburg
    Re: tuning a 2.0 8v 20seh
    That's how we got them in South Africa:
