any1 know what is the lowest mm rear spring u can get 4 a corsa gsi?
i've heard that u can get 90mm, 100mm drop springs off a stock rod?
if so were can i get sum?
EURO STYLE RULES
up
EURO STYLE RULES
up
EURO STYLE RULES
up
EURO STYLE RULES
up
EURO STYLE RULES
Speak to www.coilsprings.co.uk and they'll make you a set of springs to whatever spec/drop you want. They charge £150+VAT for a car set of 4. I have a set of their springs on the back of my Astra estate (-75mm), can't fault them at all.
You'll have to find some way of tieing the rear beam up though with those springs on, as with an 80mm or more drop, as soon as you go over a bump, the shocks will open out and the spring will fall out![]()
You can buy them upto 90mm not sure about 100 though! wh you want to go that low surely it would actually make it handle worse that low? Type it into google or something!
up
EURO STYLE RULES
There is a group buy on Corsa Sport for -80mm and -90mm rear springs.
were can iget the 90mm's from kandycorsa?
i wont them that low so i can raise/ lower with adj platforms
EURO STYLE RULES
If that's the case, I'd speak to Avo and see about getting a set of their rear 1.9" coilovers for a Nova/Corsa that just replace the standard shocks (and you throw the standard springs away, leaving the spring seats vacant). I bought a set about 4 years ago. I think they cost me about £180.
best way to go is coilovers!!
if you drop it near 100mm when you corner it will wallow and the spring will drop out
standard shocks have too much travel for use on lowered corsas.
ive heard that with rear coilovers on novas/ corsas u have2 modify the rear shocker turret quite alot? not really got money to pay 4 coilovers so throught shorter springs on adj platforms with my spax rsx shox would be a gud combo?
EURO STYLE RULES
You don't have to do major modifying to fit the Avo ones. My rear turrets were stitch welded with the rest of the car, but nothing else done. The back of mine isn't carrying any weight though as it's stripped out. You could always tack in a couple of plates to strengthen the area if you were worried.
just after springs aprox 90-100mm drop??
EURO STYLE RULES
I brought some off V sport they are a -90mm drop and they are now for sale £70 delivered to you.
Back in the scene
They yours rick or is that their offer?
