well cant really say running problem as it not running. right this is what i know i have.
spark on the plugs
working fuel pump
working relay
power to the pump when cranking
petrol in the tank
but the car fails to run its doing my head in.
spark on the plugs
working fuel pump
working relay
petrol in the tank
Have you got your pipes the correct way on your engine?
yes they are the right way round. it was running fine then just cut out.
from a broken wire, knock sensor,
i'm no mechanic but if you got a spark and fuel and she's turning over
sounds like a timtng fault, the cam belt ain't snapped has it
Is there enough fuel pressure at the rail?
could it be the fuel reg by the pump.
Could be but unlikely. Check the fuel pressure first. If there isnt enough pressure, it wont start...
thats whats i think is happening no fuel pressure.
