Astra G How to test wheel sensors?
Results 1 to 6 of 6
Thread: Astra G How to test wheel sensors?
    May 2004
    Question Astra G How to test wheel sensors?
    Hi all,
    Basically I have KW coilovers fitted to my Astra Coupe Turbo a few weeks ago.
    And since then (immediately), the TC and ABS lights are on.
    I have checked the wheel sensor connectors and they seem to be secured. I then plugged in my fault code reader, and it read "C0040", which I believe is Right Front wheel sensor. I do not believe the sensor is faulty, I think it must be a connection somewhere. I have also disconnected battery but the fault code stays.
    So does anyone know how to test a wheel sensor on the Astra G?
    On the Agila... I could just jack the car up, spin the wheels with my hand, then plug my multimeter into a connector in the engine bay to read the voltage. But on the Astra G the sensor is integrated into the hub...
    By the way, do TC and ABS still work in this situation?
    Many thanks.
    Aug 2006
    shropshire
    astra
    send me your email address and i will email it all to you from the auto data discs i have show you every thing about that how to test what they should be reading etc
    May 2004
    PM sent!
    Thanks a lot.
    Sep 2004
    milton keynes
    corsa
    when one of my ABS sensors broke, i drove along at about 25mph then slammed on the brakes and listened out for what wheel locks up
    May 2004
    Hi,
    Basically I know which sensor is it coming from (i.e. Front Right), but I just need to know whether it is
    - the actual sensor
    - the connector on the sensor
    - the connector on the ABS unit
    - the ABS unit itself
    - the ECU unit
    - some wires somewhere inbetween
    -etc
    is at fault.
    Thanks.
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    you can connect an oscilloscope to the sensor and spin the wheel to see if you are getting a good signal.
