o2 sensor wires joining
Results 1 to 3 of 3
Thread: o2 sensor wires joining
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    right ive had to extend the wires on my lambda sensor so it reaches its hole (if that makes sense) but after about half hour of driving the ecu light comes on
    when i flash it i get 13 which is lambda sensor open circuit
    what could be causing this all the wires are joined tightly and insulated well
    London, United Kingdom
    78 Kadett C
    hmmmm i've done that aswell, and i have the pesky EM light come on, but no flash codes... Does youre come on and stay or go out again?? I'd check that it's insulated properly and the joins are good... I soldered mine together, i recommend you do that too if you havent!! Also check that the wires arent catching on anything, last time i looked mine were catching on the PAS rack (im gonna check that lol)!!!
    78 Kadett C 2.0 8v turbo
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    im gonna whip it out today and shrink wrap em
    ill check all the connections then although they are very well insulated
    the light comes on after about 20mins or when i drive normally
    also i got a few afm and iat faults also which is strange
