***Advice needed asap****
Results 1 to 13 of 13
Thread: ***Advice needed asap****
    May 2001
    South Wales
    Nippy Cav Turbo
    Mate just phoned...his cav turbo just cuts out at any giving time when driving along ....wtf has done this 3 times tongiht as he drove along....the car lights dont go out..just the engine cuts out all together and he waits a few then starts 2nd time on crank up..every time. there is gas in car so no jokes lol ffs
    suspected?
    fuel filter?
    dizzy cap?
    plugs are new and have been great since put in...
    any ideas?
    cheers adam
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    Fuel pump still alive?
    Is it missing at all prior to cutting out? That discription could mean 1001 probs!
    www.shonkyopels.de
    Rob
    Rob is offline
    MIGWeb User Rob's Avatar
    Tain
    Vectra CDTi
    Coil?
    Ignition amplifier (not sure if they have one?)
    AFM fault?
    Melv - "you shouldn't be allowed boobs that size as your only a wee lassie"
    May 2001
    South Wales
    Nippy Cav Turbo
    fuel pump relay??? no miss fires it just cuts out ....... doubt its icv as it doesnt do this when car is hot etc ...
    where is fuel pump relay? by outtank pump next to the fuel tank?
    ta
    hmm coil...? if coil goes will it act like when dizzy is at fault ? where it slowly dies kinda thing? like a wet dizzy cap...?
    p.s. no fault codes so no managment light etc...and yes bulb works! lol
    hmm maybe earth strap on f28 box??
    Rob
    Rob is offline
    Tain
    Vectra CDTi
    Quote Originally Posted by Adam View Post
    Coolant temp sensor or whatever it is? The one by the inlet?
    Jun 2005
    Cracktown
    black 52' astra sxi
    as above ^^^^
    astra 2002 sxi spare parts 07521382540 wheels, cd player cdr500, lights, seats, door cards, white dials, exhaust, suspension, breaks. spoiler. wiper motors, wiper arms.
    May 2001
    South Wales
    Nippy Cav Turbo
    Quote Originally Posted by Rob View Post
    well when my cts code was on with ecu..i never had cut outs he had a new tps a month or so ago... hmm
    Jun 2005
    Cracktown
    black 52' astra sxi
    sometimes the cts can go completely faulty and give out a reading of about -43 degrees but sometimes it can give just a reading thats slightly odd for the engines temperature and make it run funny and cut out.
    May 2001
    South Wales
    Nippy Cav Turbo
    sounds like its the fuel pump relay..car just cut out up the road from house and he's noticing the fuel pump turning off a sec before car cuts out!
    Mar 2005
    Anglesey<>Manchester
    BMW, Corsa B XE
    I would go with fuel pump relay to start with - a CTS tends not to cut the engine, it will make it run lean to rich but shouldn't give enough of a reading to shut down the engine.
    You could try bridging the relay, joining the two biggest wires, so the pump is constantly running see if the fault goes away. It could be a imobiliser fault if the car has one, cutting the fuel pump relay out?
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    fuel pump relay is sometimes in the black box under the bonnet. Swap it for yours and see what happens?
    Or when it cuts out, run round and press the schrader valve but don't blame me if you're engulfed by a 6 foot flame.
    Moderator Nobbie's Avatar
    Hemel Hempstead
    with blue lights
    Yeah, fuel pump relay, small black rectangular box, normally near the passenger side suspension turret, or next to the ecu in the footwell, iirc.
    May 2001
    South Wales
    Nippy Cav Turbo
    it was the fuel pump relay as a mate thought sorted! result and ta for all ur feedback
