No boost at all .
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 45
Thread: No boost at all .
    Dec 2002
    Essex
    Lada Riva
    No boost at all .
    Just fitted recon turbo and did about 50 miles and set boost to 1 bar - 14.5psi .
    There was a bit of juddering then no boost at all after that
    Not even 1/2 a psi - just stops on gauge from idle to 0 boost .
    Taken downpipe off and used a footpump and watched the wastgate opening and shutting and also the blades on turbo spin fine ........I dunno .
    The actuator moves a fair bit by hand but saw it opening and shutting wastegate and it's a Courtenay one and fairly new .
    There are no pipe leaks and car runs and drives fine just no boost .
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    worth changing the actuator for the one off your old turbo in case theonw you have is weak?
    They're there, in their room.
    May 2001
    South Wales
    Nippy Cav Turbo
    how old is recon as u suppsoe to gradually settle them in ugg
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    You got Vacuum tubes plumbed in correctly right?
    www.shonkyopels.de
    Dec 2002
    Essex
    Lada Riva
    Quote Originally Posted by spanishfly View Post
    Taken pipe off actuator as a test and still nothing at all .
    Not sure on actuator but taking pipe off rules that out .
    Turbos don't need running in .
    Dec 2002
    Essex
    Lada Riva
    So in theory if the actuator is taken off then the engine should boost to infinity and beyond ?
    Jun 2005
    Kent
    ASTRA SRI 200XP
    taken off or the feed pipe disconnected?
    Dec 2002
    Essex
    Lada Riva
    Quote Originally Posted by xeman View Post
    Taken off has the same effect as no pipe so yeah either I spose .
    Taken off wastegate valve permanantly shut anyway I reckon .
    Jun 2005
    Kent
    ASTRA SRI 200XP
    I have never had no boost whatsover on a LET but have on other cars and if there was a boost leak on the inlet side you could REALLY hear the turbo spinning and the pressure escaping
    Dec 2002
    Essex
    Lada Riva
    Hmm nope nothing like that - no pressure escaping noises at all , infact drives just like a usual lower powered car ..fine but no boost .
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    If it drives lack that with no vac onto the wastegate then the wg is either leaking (look for a poor fitting penny valve [or missing!], or the arm moves freely), a big hole in the casing (obvious) or the turbo isn't spinning up due to resistance on the shaft.
    Dec 2002
    Essex
    Lada Riva
    Quote Originally Posted by Commander Keen View Post
    Yeah man , you see penny valve is fine and wastegate - saw it opening with downpipe off with someone operating foot pump .
    Plus spun shaft by hand that's why I'm stumped .
    Brand new turbo but it did judder before no boost at all .
    Feb 2005
    harlow essex
    into lamp posts
    turbo technics turbo
    Dec 2002
    Essex
    Lada Riva
    I was only boosting at 0.8 bar when car juddered and then no boost .
    Before I take the unit off , I have checked wastegate wich is intact and opens and shuts and with pipe off actuator there is 0 boost not even a puff .
    Blades spin by hand fine .
    There are no air leak noises and car runs perfect but no boost .
    Not turbo technics no .
    Jun 2002
    Wrectum
    when you tested it with a footpump, when did it open?
    Dec 2002
    Essex
    Lada Riva
    Gauge on footpump is crap so not sure but did open and shut ok , was looking at wastegate at the time through the bottom .
    An ecu fault can't cut all boost can it ? as the turbo is mechanical it would surely still boost .
    Jun 2002
    Wrectum
    worst ecu could do is run on spring pressure.
    Try it with the wastegate disconnected and the actuator wound right up.
    Dec 2002
    Essex
    Lada Riva
    Will have a play later
    The judder before no boost at all is what I can't make out though
    Jun 2003
    now in a evo
    1.4bar = 356bhp :-)
    you say you span the shaft! but did you check the other fan was turning while you turned the exh fan?
    Jun 2003
    now in a evo
    1.4bar = 356bhp :-)
    you would still have boost with the wastegate jammed right open
    Oct 2002
    Thats what i'm thinking... a snapped or loose shaft!
    www.shonkyopels.de
    Dec 2002
    Essex
    Lada Riva
    Both sides of shaft turn together as got someone to check .
    So it has to be the new turbo at fault then no ?
    There is no shaft damage , it turns but no boost .
    I'm even more lost than normal .
    Oct 2002
    If both ends of the shaft turn,
    you got no problem with the wastegate/actuator,
    then engine runs perfectly bar the boost,
    You got a big problem?
    www.shonkyopels.de
    Dec 2002
    Essex
    Lada Riva
    Hmm , strange problem and annoying .
  26. #25
    Jun 2003
    now in a evo
    1.4bar = 356bhp :-)
    Quote Originally Posted by daddy cav View Post
    i'm stumped because, if your turbo spins freely by hand and both impeller's are connected then its gona spin like a good un , and create some airflow (boost) i would then go to say that you have a boost hose off , but the fact your running a AFM with no tickover/running problems is errrrrr
    no boost as in " 0 " ?
