V6 Hit and Miss!
Results 1 to 10 of 10
Thread: V6 Hit and Miss!
    Aug 2006
    Sunderland
    Cav 3.0 v6
    Wtf V6 Hit and Miss!
    Hi, can any1 help
    on saturday sunday and tuesday my cav v6 was working fine, very quick 0-60 about 7 secs and nice induction roar, reving freely!
    Today its very quite even at high revs, dosent want to rev and is about 12 secs 0-60!
    Wat tha feck??
    MIGWeb User Add_Gee's Avatar
    Mar 2002
    Birmingham
    Vectra B SRi 2.2 Estate
    i guess you have an induction kit? anything blocking it?
    MIGWeb Moderator
    Midlands
    Nowt
    No fault codes stored?
    May 2005
    Bristol
    V6 Calibra
    They were warm days too???
    My V6 has sunddenly got a lot better with the cold weather this week i love it!!!! But in the warm it sucks
    And yes i know why........ i have a cone filter which is happily sucking hot air from my engine lol
    Apr 2001
    NW England
    04 STi jdm
    Quote Originally Posted by Paul
    As above read the fault codes (if any)
    Mine has always run spot on apart from when the leads went duff.
    Mart
    A member of MC Automotive
    Aug 2006
    Sunderland
    Cav 3.0 v6
    How do you check if the falt codes? and it was the same weather each time, just sometimes its as if the car is not breathing at high revs, other times its like a rocket. the time it was last under powered was a cold night, it was working fine last sunday day time which was red hot. i'm goi to clean plugs and change leads this week, see if oil is getting in! as its pissing out the front cam cover on to the manifold, just had a new gasket fitted the cover must be warpped!
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    Change the plugs, they are only a couple of quid each from Vauxhall.
    Sep 2006
    Boston, Lincolnshire, Un
    Quote Originally Posted by Mark T
    yeah but a big job to put in! an hour in fact
    Sep 2006
    my v6 had good days and bad days and i only had a drilled air box
    Aug 2006
    Sunderland
    Cav 3.0 v6
    PRoblem solved!
    It was the throttle cable clip had come off and cable was stuck in the gromit, so even tho i had the accelerator pedal pushed right in i was only at 1/2 throttle, I've fixed it with some Pykey PVC tape until i get a chance to get to vauxhall or a scrappy to get a new clip!
    I've only ever driven my v6 cav, and when i had the egine fitted i had had a regal cool stst fitted, but the engine now runs at about 95c, wat do standard ones run at, or do i just need a a fan switch to go with it?
