I had a thread not so long ago about getting my speedo to read right after futting the F28 in my corsa, its all cable driven so there seems to be no way of adjusting the reading. what i am going to do is get hold of some electronic corsa clocks and a pulse adjuster (maybe one from dom if they are ready) but that leaves me needing an electronic signal to start with.
Did any F28 gearbox have an electronic sender fitted to it as standard? Would a sender from an F20 fit and were these ever fitted with an electrical sender?
failing all that i have found this site http://www.huntertransducers.com/searchdetails.asp?ID=11 which sellsthe pulse generators so if all else fails ill get one of those, how many pulses per rev would i need to get the pulse rate in the right ball park?
Any help as always is much appreciated! thanks
