Anti rattle pins for rear brake pads
Results 1 to 7 of 7
Thread: Anti rattle pins for rear brake pads
    Rob
    Rob is offline
    MIGWeb User Rob's Avatar
    Tain
    Vectra CDTi
    Is there a way of getting these in without taking the caliper off etc?
    The pads rattle like hell over bumps and its seriously doing my head in. 99% sure I have the little curly things, just need them in. The car is going into the garage on Monday anyway so would it be easier just to get them to do it?
    Melv - "you shouldn't be allowed boobs that size as your only a wee lassie"
    Gagged
    Jan 2005
    Poole
    BMW M3 Ltd Ed
    I take it these are different to the old cav disc/drum combo, or you wouldn't be asking? 2 minute job.
    I had some that were rattling, tried everything you could think of. Was the handbrake adjuster on the beam lmao
    Rob
    Rob is offline
    Tain
    Vectra CDTi
    AFAIK, they are different to the cav's.
    They rattle over bumps but it stops when I press the brakes. Wheel off and jam the fecker in?
    Gagged
    Jan 2005
    Poole
    BMW M3 Ltd Ed
    Be nice to see a pic of the set-up, never worked on them. Can't see why they had to change them, maybe it was too quick and easy to change the pads, so had to over-complicate it?
    Either way, caliper's just 2 bolts, or have they messed about with that too? lmao
    Sorry for the lack of help
    Rob
    Rob is offline
    Tain
    Vectra CDTi
    no.... I am sorry for the lack of info! I just assumed a mk4 expert would reply!! lmao
    the hand brake cable comes up from the bottom and hooks over a V style holder. there is one bolt at the top of the caliper and its hinged on the bottom. Caliper wont come off without the handbrake cable being off and thats where I got stuck last time.
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    The AstraG (and VecC) calipers have a mechansim on that operates the brake caliper with the handbrake cable.
    Take them off and have a loook.
    it's only 2 bolts.
    be careful with the brake pipe.
    You can back off the handbrake cable in the car IIRC.
    Rob
    Rob is offline
    Tain
    Vectra CDTi
    Quote Originally Posted by Mark T
    it's only 2 bolts.
    how do I back off the cable? The garage who fitted the brakes I supplied are doing the mot on Monday so I might just get them to fit them. I was hoping for a 'quick fix'
