Vectra C temperature sensor
Results 1 to 10 of 10
Thread: Vectra C temperature sensor
    Oct 2005
    Manchester
    Vectra 2.2 DTi SRi
    My outside temp is reading -30 or something stupid.
    Will this be the outside temp sensor?
    Where are they on the Vectra C?
    Is it possible to test them? I know they are only a fiver on flea bay but if it aint broke....
    Jan 2006
    crewe
    corsa b 20xe
    yea it'll be the sensor, they're in the front bumper/lower grille, 1 of the 2
    Oct 2005
    Manchester
    Vectra 2.2 DTi SRi
    Cheers for the reply. So can you fix them or test them?
    Or will I just need to get a new part?
    Jan 2006
    crewe
    corsa b 20xe
    to be honest i have never tried testing them as its always been the sensor, and they are a sealed unit so very doubtful its repairable, best of putting a new 1 in mate
    Oct 2005
    Manchester
    Vectra 2.2 DTi SRi
    Had it in the shop, fault code showed sensor circuit.
    Replaced sensor.
    **** all.
    So what else can it be? A short? HEEEEEEEEEEELLLLLLLLP!
    It cost me £60 for the diagnosis, £2.50 for the sensor, and I'm no better for it.
    Jan 2006
    crewe
    corsa b 20xe
    £2.50 for the sensor, thats cheap, ours r about £15!!! errrm, only thing left is the wiring to the sensor its self, shouldn't be too hard to trace back as there's only 2 wires.
    theres bound to be a fuse 4 it, has that been checked?
    Oct 2005
    Manchester
    Vectra 2.2 DTi SRi
    Not sure...
    Is it easy to change the wiring to the sensor?
    I assume fuse is OK because there is 'a' reading.
    Today, however, it did say
    c
    F
    Where it would usually have a number.
    May 2003
    Belgium
    '90 opel omega
    it won't be the LCD display that's broke, would it?
    Note: the above may or may not be entirely correct.
    I wondered why the frisbee was getting bigger, and then it struck me.
    Oct 2005
    Manchester
    Vectra 2.2 DTi SRi
    No, it shouldn't be, its working fine in all other areas, today it was back to minus 35 degrees. Should I get another new sensor and replace the wiring on it?
    Thoughts?
    Aug 2005
    Sussex
    i reckon youve got some dodgy wiring mate. these sensors work on varying resistance to give you a reading. a dodgy connection or even a dodgy earth could be messing the resistivity of the circuit. if you know how to use a multimeter get busy!!
