coolant temp sensor
Results 1 to 7 of 7
Thread: coolant temp sensor
    MIGWeb User spuds_own's Avatar
    Apr 2005
    Rotherham
    golf vr/ mk2 gt
    coolant temp sensor
    can the wires be on reverse polarity?
    snd flood the engine?
    Have YOU ever tried licking your balls????
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    No, it's just a resistance that varies according to engine temp. If one of the wires to it is broken, this will flood the engine. Also the ECU light won't come on with the ignition, and should come on when the engine is running, if you can get it started.
    They're there, in their room.
    Apr 2005
    Rotherham
    golf vr/ mk2 gt
    thats the trouble it coughs on first turn of the key then floods
    Apr 2005
    Rotherham
    golf vr/ mk2 gt
    its also a new sensor
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Check the wiring. Preferably at the ECU connector, you should see resistance.
    Engine type and size and age?
    Also, if it failed recently, even with a new sensor it'll need a lot of cranking to get it going again.
    Apr 2005
    Rotherham
    golf vr/ mk2 gt
    c20xe 91ish its in a corsa
    is that at the ecu end? if so what pins?
    Apr 2005
    Rotherham
    golf vr/ mk2 gt
    cmon peeps
