Corsa sxi Rear Wheel Bearings
Results 1 to 4 of 4
Thread: Corsa sxi Rear Wheel Bearings
    Jun 2004
    Rossendale, Lancs
    Corsa Sxi C 1.2 02'
    Hi there just a quick question if anyone can help:
    I am replacing the drums on the rear of my 2002 Corsa sxi and see they carry the wheel bearings, the car has done 52,000 miles should I replace them or can they be removed/pressed out? If I have to replace them anyone any ideas of cost or suppliers.
    Many thanks
    Jay_nation
    Dec 2005
    walsall
    corsa c20let
    do they need replacin? id just stick sum greese in there if they dnt. nt sure about hw to get them out but the ones i did on a mondeo needed to be machine pressed out.
    Nov 2000
    North Ayrshire
    6J Ibiza FR TDi
    if they are the same set up as the Nova and Corsa B then I'd change the wheel bearings at the same time. In my experience they only last about 60K miles. New bearings are about £15 per side.
    VAG history - BLT | CFHD
  5. Remove Advertisements
    Jun 2004
    Rossendale, Lancs
    Corsa Sxi C 1.2 02'
    Thread Starter
    Many thanks for both your replies.
    The bearings are slightly worn so going to replace them, they definately require pressing out after further investigation. I believe attempting to remove them with convensional methods may damage them.
    Thanks for you input.
    With regards
    jay_nation
