Ignition Barrel Removal????
Results 1 to 10 of 10
Thread: Ignition Barrel Removal????
    Mar 2006
    Question Ignition Barrel Removal????
    Sorry if this question seems stupid but here goes
    I have bought a 2nd hand column for my corsa C and after some good answers on my last post i am now resolved to change the whole column instead of getting away with just exchanging the ECU or ESP Motor
    the problem i have is that the column came without an ingnition key so i cant use the prescribed method to exchange the ignition barrel for my own one.
    it was suggested that i would need to use a hammer but where do i need to hit it?
    please help if you can as i don't want to **** up the new column by doing this wrong
    thanks for any help
    Roj.
    Aug 2005
    Glasgow
    Vectra CDX
    Hmmmmm
    How do we no your not going to steal lots of Corsa's if we tell you LOL
    Mar 2006
    I just need to fix my van so i can put my 8 stone german shepherd security dog in the back and go out to catch some of the low life thay are refering to.
    By all means check me out.
    my website - www.gsd-security.co.uk
    scroll down and you can see a picture of my dog in the back of my old astra.
    Awaiting Email Confirmation
    Jun 2002
    just take the column to a locksmith then and they'll cut you a key toot sweet and cheep.
    MIGWeb User novadosed's Avatar
    Mar 2002
    North Wales
    Nova 1600
    remove the cowlings, on top of the barrel housing should be a small hole. flick barrel to position 1, push down through the hole on the plastic which will push a tag into the barrel itself then pull. easy!
    when reffiting u need to push down the lock tag inside the new column with a long screwdriver, it is inside the new column where the barrel sits.
    hth! chris
    Nova Merit 1.6 H993 XMA - R.I.P
    Mar 2002
    North Wales
    Nova 1600
    you will also need to swap your immobiliser and ignition switch
    Jul 2002
    Leamington Spa
    Nissan Fairlady Z / JTin
    Use a smallish allen key to poke through the hole. The key must be in the ignition.
    2002 - 2012, 19,000 posts - Celebrating 10 sad years on MIGWEB
    Nov 2002
    Livingston
    he doesnt HAVE the key....
    think you need to break the bolts that hold the barrel mech round the column and replace the whole thing
    Mar 2006
    ttt
    Jun 2005
    Cracktown
    black 52' astra sxi
    put a sturdy flat head into the barrel where the key goes into hit the end of the screwdriver intil its in about 1.5cm then use mole grips and turn the screwdriver. that will allow you to turn the ignition so its turned on and the push an allen key into the small hole and draw out the barrel.
    i would come and help but im not going to smash off an ignition barrel with that dog near by sorry. even though my missus has six of them.
    astra 2002 sxi spare parts 07521382540 wheels, cd player cdr500, lights, seats, door cards, white dials, exhaust, suspension, breaks. spoiler. wiper motors, wiper arms.
