brake imbalance
Results 1 to 9 of 9
Thread: brake imbalance
    Mar 2006
    brake imbalance
    Just had the corsa in for its mot, failed on the rear brakes. Guy said 53% on rear wheel breaking dont know whether that means it only has 53% out of a higher percentage. or if its an inbalance betten each rear wheel or imbalace between front and rear?? Any ideas?
    Nov 2002
    Livingston
    inbalance on the rear is side to side usually
    probably means one sides got leaking oil seal or fluid or is just done but ur gonna have to take them apart to find out
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    Corsa C SRiT & Meriva VXR
    It'll be an inbalance between tthe rears,ime it'll just require readjusting,providing ofcourse the rear brakes are in good condition.
  5. Remove Advertisements
    Mar 2006
    Thread Starter
    okay dokie so does that mean that one side is working 50% better than the other side? thanks guys
  7. #5
    Nov 2005
    Dundee, Scotland
    Skoda Fabia vRS
    Gotta strip each side down, see if there is anything leaking. If so, replace both sides...
    If not, give the drums a good rub down, a really good rub, with the roughest sandpaper you can find! Then something a bit finer for the shoes...
  8. #6
    Mar 2006
    Thread Starter
    arite again! yeah guna do all that in a while just wanted to know where i stand with this percentage didnt ask the guy exactly as had a bit of an argument wi them, hehehe! di*ks
  9. #7
    Nov 2005
    Dundee, Scotland
    Skoda Fabia vRS
    Well, same happened with my old clio, had a rear brake imbalance, checked nothing was seized, gave the shoes a light rub to get rid off the top layer of sh*te, and took a grinder to the lip of the drum lmao
    Then just rubbed sh*t out of the drum, threw it all back together and it passed! lmao
  10. #8
    Mar 2006
    Thread Starter
    haha nice! well im away out to put work on it i'll kepp u posted on what the pice o .... throws at me 2day!
  11. #9
    Mar 2001
    Torquay
    Audi A3 07 170 DSG
    Could be the bias valves.
