Old 10-01-2006, 18:44   #1
Drives: Mk 2 Astra 1.3 E reg
Cav auto box/shudder
1.8 on startup the light comes on and on occasion box has to be changed manualy also it has a bit of a shudder at idel though this may be unrelated any ideas if it can be fixed cheep.
Mk2 man is offline   Reply With Quote
Old 10-01-2006, 19:11   #2
Dom
Dom's Avatar
Drives: Vectra SRI
Mine judders a bit at idle.
Could be a faulty or corroded selector switch on top of the gearbox - best thing to do is to flash out the fault codes from the gearbox ecu and see why its complaining.
Doms online blog - www.picbits.co.uk/forums but you'll have to register to read it.
Dom is offline   Reply With Quote
Old 10-01-2006, 20:35   #3
Drives: Subaru Outback
The first step with any autobox faults is to change the fluid, unless it's been done recently. This applies to any type/make of autobox. For many GM autoboxes, there's no recommended fluid change interval, ever, but it's a cheap way to ensure long life.
I presume it's a Mk3 Cavalier 1.8 - if so the box is an Aisin-Warner AF20 (jap-built, tough as old boots normally). You'll need 3 - 3.5 litres of Dexron 2 or 3 (Dexron 3 is the later, better, more expensive type but either 2 or 3 is acceptable for the Cavalier.
The drain plug is at the rear right-hand side of the transmission, below the driveshaft. Refill through the autobox dipstick tube, just 3 litres to start with, then check the level with the engine idling for 2 minutes, checked against the +20 side. Don't add more than 0.25 litre without re-checking.
RogerL is offline   Reply With Quote
Old 10-01-2006, 20:37   #4
Ah yep ots a mk3 might be a doggy sensor most of the time its ok but can be a compleat pig.
Members: 43,233
Threads: 310,682
Top Poster: LEE69 (43,151)
