10-01-2006, 00:31
#1 | | MIGWeb User
| any miggers who can't sleep help me i have a prob with my rear drum anyone wanna come over
north london |
10-01-2006, 00:33
#2 | | MIGWeb User
| i can't get the bloody drum off how help |
10-01-2006, 00:36
#3 | | Gagged
Join Date: Jan 2005 Location: Poole Drives: BMW M3 Ltd Ed
| Tried adjusting off the cable?
Is it the type you can wind the shoe adjustment off through a hole in the drum?
If the drum is badly worn, may have to rip it off along with the shoe pins.
__________________ ///MPOWER |
10-01-2006, 00:38
#4 | | MIGWeb User
Join Date: Jan 2005 Location: Infractionville, CA Drives: admin up the wall
| Car? If removed it should pull off, if not put equal force behind the drum and the back plates 180 degrees opposite each other!
__________________ You can't moderate me, I am far too important! |
10-01-2006, 00:47
#5 | | MIGWeb User
| Quote: |
If the drum is badly worn, may have to rip it off along with the shoe pins. |
i dunno how would i find out ???
and i tried outting pressure on euther side but it just diesn't wanna come off that lasr bit
well what is happening is that break fluild is seepin from the rear drum, is there anyway i can stop that particular feed to that pipe temporaraly just so i can drive it to a garage |
10-01-2006, 00:50
#6 | | MIGWeb User
| Put a facking great clamp on it? Its diagonally split though, probs not too safe?
Put equal force on whilst someone gives it hammer! Dont mean this rude but the hand-brake is off isnt it?  |
10-01-2006, 00:51
#7 | | MIGWeb User
| Quote: |
Originally Posted by wayne451 Put a facking great clamp on it? Its diagonally split though, probs not too safe?
what do u mean clamp ????
to be honest i was having trouble then realise the hand break was on lol but its off now and the drum is like half off |
10-01-2006, 00:53
#8 | | MIGWeb User
| If the drums is half off its not much more to get it off! Just slap the **** out of it and be prepared to put the adjusters/springs etc back together!  |
10-01-2006, 00:56
#9 | | MIGWeb User
| do u know why brake fluid would be leaking from the drum, it happened all of a sudden when i had to break hard |
10-01-2006, 00:59
#10 | | MIGWeb User
Join Date: Sep 2001 Location: Portsmouth Drives: black jap thing
| probaly burst the wheel cylinder seal, not that hard to replace or expensive, prolly £8-£10 for a new one. |
10-01-2006, 01:00
#11 | | MIGWeb User
Join Date: Nov 2002 Location: Livingston Drives: Mk3 Astra
| youve popped a seal on the rear cylinder |
10-01-2006, 01:01
#12 | | MIGWeb User
| Quote: |
Originally Posted by SXiAstra do u know why brake fluid would be leaking from the drum, it happened all of a sudden when i had to break hard | Slave cylinder! |
10-01-2006, 01:01
#13 | | MIGWeb User
| Quote: |
Originally Posted by Jamie_F probaly burst the wheel cylinder seal, not that hard to replace or expensive, prolly £8-£10 for a new one. |
where from ???
so its a diy replace, could you run me through it quickly please |
10-01-2006, 01:06
#14 | | MIGWeb User
Join Date: Mar 2005 Location: Anglesey<>Manchester Drives: BMW, Corsa B XE
| If its just a drum, and there is a large center nut that holds the bearing on, take off the nut, then put the wheel back on and use the extra width of the wheel so you can pull the drum off - dunno if its the same but this is the way I used to get the drums off my ax and 205. The other way is the pull on one side, whilst hammering the opposite side, then swop where you were hammering with where you were pulling, keep doing that and the shock will work it off. |
10-01-2006, 01:07
#15 | | MIGWeb User
| get it from a motor factors, and go to halfods and get an eazi-bleed kit and some brake fluid.
undo the pipe going to the back of the cyliner, then there should be aeither a 10 or 13mm bolt holding the cylinder in place, undo this the remove the cylinder then replace and bleed, reatty straight forward, just depends on how hard the pip and nut are to get off, give it all a good soaking in wd40 first just to help it along. |
10-01-2006, 01:08
#16 | | MIGWeb User
| Quote: |
Originally Posted by wayne451 Slave cylinder! |
whats that ?
sounds expensive  |
10-01-2006, 01:19
#17 | | MIGWeb User
| how much ? |
10-01-2006, 01:21
#18 | | MIGWeb User
| Same as Jamie said above! I replaced both slaves and drums on each side for £22 IIRC! |
10-01-2006, 01:24
#19 | | MIGWeb User
| can i get away with doin one now and the other in a few weeks, im really short of cash |
10-01-2006, 01:26
#20 | | MIGWeb User
| Yes, you probably only have 1 leaking if thtats the fault so identify the side and replace that one! I like to keep things in symetrical! |
10-01-2006, 01:29
#21 | | MIGWeb User
| its a fooking pain i nearly went into the back of a bmw |
10-01-2006, 01:30
#22 | | MIGWeb User
| so i need to get up in the morning get a new part then come back at fit it theb u gotta go to work |
10-01-2006, 01:37
#23 | | MIGWeb User
| how long do u think it will take ? |
10-01-2006, 01:43
#24 | | MIGWeb User
Join Date: Jun 2003 Location: Luton Drives: Calibra Turbo
| You'll also need an Eazi bleed kit at about £15-20 to bleed the brakes as Jamie said, plus a botle of brake fluid at about £6 and the slave cylinder for about £10ish.
Have you bled brakes before?
__________________ |
10-01-2006, 02:24
#25 | | MIGWeb User
| no can u tell me what todo  |
Members: 43,232
Threads: 310,682
Top Poster: LEE69 (43,151) | | Welcome to our newest member, hayden222 | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
