06-01-2006, 23:02
#1 | | MIGWeb User
Join Date: Nov 2005 Location: Norway Drives: Astra Mk2 3.0V6Turbo
| Bad chassis on Astra mk2 I have some strange movement in the front of the car.When I turn the steeringwheel from side to side the hole front of the car moves from side to side.When i look at the lower corner of the frontwindow there is movement betwen the plastic that covers the whipers and the front arche.Does any other has this sort of play/movement in the chassis?
I think I have some problem in the frame? |
06-01-2006, 23:10
#2 | | Gagged
Join Date: Jan 2005 Location: Poole Drives: BMW M3 Ltd Ed
| Think you want to check the bulkhead for rot and cracks,.
__________________ ///MPOWER |
06-01-2006, 23:11
#3 | | MIGWeb User
06-01-2006, 23:22
#4 | | MIGWeb User
| Where/what is the bulkhead? |
06-01-2006, 23:23
#5 | | MIGWeb User
| Quote: |
Originally Posted by daveb948576 | I wish I could. |
06-01-2006, 23:24
#6 | | Gagged
| Around where the steering rack rods bolt on, behind the engine in the centre.
Get someone to move the steering with the car on the ground, and watch for movement and flexing. Just have a good look around. |
07-01-2006, 01:09
#7 | | MIGWeb User
Join Date: Oct 2005 Location: cymru Drives: the best car ever!
| what's this about a 3.0 v6 turbo?
__________________ Quote: |
Originally Posted by toj28 just got to figure out to get it larger as my wife normally does it. | |
07-01-2006, 08:41
#8 | | MIGWeb User
| Quote: |
Originally Posted by C4llyT Around where the steering rack rods bolt on, behind the engine in the centre.
Get someone to move the steering with the car on the ground, and watch for movement and flexing. Just have a good look around. | There are lots of movement in the wall behinde the engine,but I cant see where its coming from.Everything moves,the wall.the front frame arms,the two points where the steering rack is connected to the wall also moves. |
07-01-2006, 09:02
#9 | | MIGWeb User
Join Date: Aug 2004 Location: Sheffield, S. Yorks Drives: GT
| Sounds like the bulkhead may be cracked around the rack mountings, quite common on the MK2's. You really need to check for cracks/rot before you go driving it about. |
10-01-2006, 19:21
#10 | | MIGWeb User
| Quote: |
Originally Posted by gatecrasher3 Sounds like the bulkhead may be cracked around the rack mountings, quite common on the MK2's. You really need to check for cracks/rot before you go driving it about. | Does there exsist pictures of this problem? |
10-01-2006, 19:24
#11 | | MIGWeb User
Join Date: Nov 2004 Location: West Wiltshire, UK Drives: Astra GTE 2.0L 8V
| Yes lots of detail on www.astra-mk2.com
__________________ He's ever so good, he's Ebeneezer Goode |
Members: 43,233
Threads: 310,683
Top Poster: LEE69 (43,151) | | Welcome to our newest member, Fadge | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
