06-01-2006, 11:43
#1 | | MIGWeb User
Join Date: Jan 2006 Location: RENFREWSHIRE SCOTLAN Drives: VECTRA GSI V6/VX220
| Gsi V6 Problems HELP??
IVE GOT 2.5 GSI AND HAVE A PROBLEM THAT OCCURS AT AROUND 80mph and it sounds like a rumbling from front wheels so first a checked wheel balance not that! then changed cv's both sides in and out still not fixed!
and finally changed wheel bearings but the problem still there!
CAN ANYONE GIVE ME ANY ADVISE before i loose the rag!! :  |
06-01-2006, 12:08
#2 | | MIGWeb User
Join Date: Oct 2005 Location: cymru Drives: the best car ever!
| have you got aftermarket wheels like tsw/wolfrace etc?
__________________ Quote: |
Originally Posted by toj28 just got to figure out to get it larger as my wife normally does it. | |
06-01-2006, 13:16
#3 | | MIGWeb User
| v6 problems no mate standard gsi wheels thought it might be wheels not round but swaped front to back and problem still there!
thought it might be gearbox related but gearbox was in previous vectra with now problems . only changed gearboxes couple months ago! doin ma head in!! |
06-01-2006, 13:33
#4 | | MIGWeb User
Join Date: Aug 2001 Location: London Drives: BMW 328i sport
| checked your tracking? could be a driveshaft problem to the gearbox
__________________ roshan_j81@hotmail.com - Life moves pretty fast. If you don't stop and look around once in a while; you could miss it............ |
06-01-2006, 14:08
#5 | | MIGWeb User
| put the spacer on between the hub and hub nut? |
06-01-2006, 14:13
#6 | | MIGWeb User
Join Date: Nov 2001 Location: Leicestershire Drives: Vauxhall Corsa GSI
| Yeah have you got spiggot rings fitted to ya alloys, without these holding the wheel tight to the hub the wheel is likely to flex, have you notice any uneven tyre wear
__________________ If it aint broke dont fix it |
06-01-2006, 14:17
#7 | | MIGWeb User
| why would he need spiggot rings if he's got standard GSi alloys....
Read the posts before advising |
06-01-2006, 19:15
#8 | | MIGWeb User
| v6 problem ROSH I have tried changing the o/s driveshaft small and large and also tried replacing the mid bearing between the two shafts, the only shaft i havent tried changing is th n/s one ? |
08-01-2006, 16:38
#9 | | MIGWeb User
| Has the car been in an accident? |
09-01-2006, 19:50
#10 | | MIGWeb User
| v6 problems yeh rosh the rear of the car was damaged but no damage to front dont think this would put front end out ? I am getting to the stage that i will have a look at ever possible cause , |
09-01-2006, 20:10
#11 | | MIGWeb User
| have you tried getting upto just above when the noise starts and dipping the clutch and knocking it into neutral ? |
10-01-2006, 08:49
#12 | | MIGWeb User
| mmmm check the subframe |
10-01-2006, 18:50
#13 | | MIGWeb User
| v6 problems i have tryed dipping the clutch at speed but the noise still persists ! wondering if it could be drive shaft bent on n/s? as changed the shafts on o/s along with cv's. subframe being out of line or bent shouldnt cause knocking noise at speed i wouldn't of thought ,I will have it checked out anyway .
Thanks for all your sugestions guys |
10-01-2006, 18:54
#14 | | MIGWeb User
| i have seen this a couple of tomes before but turned out to be simple things like loose subframe bolts, wishbone bushes, tracking, even seen it happen with strut top worn |
Members: 43,224
Threads: 310,664
Top Poster: LEE69 (43,151) | | Welcome to our newest member, LaurenEnzo | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
