Advertise Here - Click for More Info
LinkBack (14) Thread Tools
Old 16-12-2005, 16:25   14 links from elsewhere to this Post. Click to view. #1
gte86
Drives: wide arch nova xe
Nova rear disc conversion
have got my astra gte rear beam sittin in front of me and want to put the discs on my nova beam. is it just a case of changing the stub axle or is there more involved. i noticed that the handbrake runners are differnt, do i have to cut and weld this?
have done a search and couldnt find any info that helped me. any one know a site or a link with a 'how to' guide.
also do i have to fit nova saloon bias valves, and where are these located.
any help much appreciated. Tom
My PB=15.222@87.93.....I need carbs!
R1 Carbs soon to be fitted!
M&M Motorsport
gte86 is offline   Reply With Quote
Old 16-12-2005, 16:55   #2
gte86
any gen? i need to get it done this weekend.
Old 16-12-2005, 17:22   #3
Kieran
Drives: 2.0 Nova, Astra Mk3
Unbolt the hub assemblies off each side of the beam. You'll see a 10mm thick plate welded on each side of the beam that has the Astra stub axle stud pattern drilled in it. You'll have to cut these plates off the Astra beam and weld them on the ends of your Nova beam (after removing the 10mm thick plates off the Nova beam with the Nova stud pattern in). Once the plates are welded on, use the holes as a template to drill the Astra stud pattern in the Nova beam. Then you can just bolt everything in place.
Kieran is offline   Reply With Quote
Old 16-12-2005, 17:24   #4
Kieran
Almost forgot, the bias valves are screwed into the side of the master cylinder under the bonnet. Ideally, you want the 3/25, 3/27, or 3/30 valves. The lower the second number, the more restrictive they are.
Old 16-12-2005, 20:31   #5
Benn
MIG Regions / South Central Regional Coordinator
Benn's Avatar
Drives: A shineeeey Let Nova
one think i will say,
is people say use differenthand brake guilds,
well done
use the nova ones,and a mk3cav handbrakes cable,
Man I just stopped caring, the music is blaring
I feel you glaring, why wont you stop staring?
Old 17-12-2005, 00:47   #6
Chris S
Drives: GT35R 1.2 LS
if u dont fancy cutting the plates off ive got a pair laser cut,
ฃ22 delivered
6 SPEED, LSD, MINT GREEN BALLISTIC BOGEY. TOTB 09 FWD SHOOTOUT WINNER
11.6 @ 126 1.9 60FT
MAPPING AND SETUP BY RICKY @ www.race-tech.co.uk
Chris S is offline   Reply With Quote
Old 17-12-2005, 00:49   #7
DutchNovaDiesel
Drives: '97ComboD '93NovaTD
Grind off the old plates: (be sure NOT to cut in to the beam itself)
Nice and clean axle, ready for the astra plates:
Difference between nova(left) and astra (right):
Astra plates welded on the nova beam:
You might want to cut some slits in the beam like this (and bend the thin end outwards):
Otherwise the bolts will be very close to the beam (i modded the bolts):
Finished:
On the car with new brake pipes (old ones can be bent to fit...but it is not 100% guaranteed to work, you could snap them wile bending)
'91 Nova long cable, '89 Cav 1.6 short cable extended with a piece of threaded bar (M8)
The bias valves i'm using are the originals mounted on my nova van (3/30)
My advice: source a second rear axle and take your time...
Cheers, J
Complete manual can be found HERE
Manual is written for the complete kit...using astra handbrake cables.
DutchNovaDiesel is offline   Reply With Quote
Old 17-12-2005, 02:11   #8
Benn
Benn's Avatar
Originally Posted by DutchNovaDiesel
whats that?
is that the hand brake guild?
Old 17-12-2005, 09:39   #9
DutchNovaDiesel
Nope, just a picture of grinding the old plate off
Old 17-12-2005, 13:11   #10
BarryGTE
Drives: Evo5Tigra
excelent write up that mate,this should be put in the how to section
BarryGTE is offline   Reply With Quote
LinkBack to this Thread: http://www.migweb.co.uk/forums/other-mechanical-electrical/240889-nova-rear-disc-conversion.html
Posted By For Type Date
Discuri pe spate, posibil? This thread Refback 21-06-2009 20:25
Discuri pe spate, posibil? This thread Refback 20-06-2009 03:58
Recent Posts This thread Refback 19-06-2009 21:21
Is not the first Astra F, is the third !! This thread Refback 19-06-2009 13:27
Is not the first Astra F, is the third !! This thread Refback 19-06-2009 10:06
Is not the first Astra F, is the third !! This thread Refback 19-06-2009 09:28
Is not the first Astra F, is the third !! This thread Refback 19-06-2009 09:09
Corsa Sport - Modyfikacje, tuning, forum oraz klub corsy. • Zobacz wฤ…tek - Tarcze z tyล‚u This thread Refback 04-01-2009 23:08
Corsa Sport - Modyfikacje, tuning, forum oraz klub corsy. • Zobacz wฤ…tek - Tarcze z tyล‚u This thread Refback 04-01-2009 21:54
ื”ืชืืžืช ืกืจืŸ ืื—ื•ืจื™ ืฉืœ ืงื•ืจืกื” ืœื˜ื™ื’ืจื” - ืงืืจืกืคื•ืจื•ื - ืจื›ื‘ื™ื \ ืžื•ื˜ื•ืจื™ืงื” - ืคื•ืจื•ื ืจื›ื‘ This thread Refback 14-02-2008 09:03
ื”ืชืืžืช ืกืจืŸ ืื—ื•ืจื™ ืฉืœ ืงื•ืจืกื” ืœื˜ื™ื’ืจื” - ืงืืจืกืคื•ืจื•ื - ืจื›ื‘ื™ื \ ืžื•ื˜ื•ืจื™ืงื” - ืคื•ืจื•ื ืจื›ื‘ This thread Refback 14-02-2008 07:26
ื”ืชืืžืช ืกืจืŸ ืื—ื•ืจื™ ืฉืœ ืงื•ืจืกื” ืœื˜ื™ื’ืจื” - ืงืืจืกืคื•ืจื•ื - ืจื›ื‘ื™ื \ ืžื•ื˜ื•ืจื™ืงื” - ืคื•ืจื•ื ืจื›ื‘ This thread Refback 11-02-2008 05:38
ื”ืชืืžืช ืกืจืŸ ืื—ื•ืจื™ ืฉืœ ืงื•ืจืกื” ืœื˜ื™ื’ืจื” - ืงืืจืกืคื•ืจื•ื - ืจื›ื‘ื™ื \ ืžื•ื˜ื•ืจื™ืงื” - ืคื•ืจื•ื ืจื›ื‘ This thread Refback 11-02-2008 05:31
ื”ืชืืžืช ืกืจืŸ ืื—ื•ืจื™ ืฉืœ ืงื•ืจืกื” ืœื˜ื™ื’ืจื” - ืงืืจืกืคื•ืจื•ื - ืจื›ื‘ื™ื \ ืžื•ื˜ื•ืจื™ืงื” - ืคื•ืจื•ื ืจื›ื‘ This thread Refback 10-02-2008 19:52
ฉMIGWeb 1997-2009 - MIGWeb Home - Archive - Privacy Statement - Top
Powered by: vBulletin. Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0
