ABS playing up
Results 1 to 2 of 2
Thread: ABS playing up
    Sep 2001
    Sheffield
    Mk2 Astra Estate
    ABS playing up
    when going at slow speeds ie under 10 mph, and turning i can feel the abs cutting in through the pedal, its only done this a few time in the past couple of days but i remember sombody else have this trouble a while back but cant remember what caused it?
    Any gen?
    Mar 2001
    UK
    91 Calibra 8v
    A faulty ABS speed sensor on the front.
    You have two choices.
    Read the ECU for fault codes and change the faulty sensor,
    or;
    Remove both front sensors and clean them up, and also clean up the ABS speed ring.
    If you go the new sensor route, (which you will mostly likely will have to do), you will need to get a new ABS sensor mouting bracket.
    NEWS : Vauxweb Stickers NOW available.
    Click here to visit Vauxweb or here to visit the Forums
    Powered by Invision Board, a Free PHP powered mySQL forum software .net Recommended Free Forum Round Up - September 2002
    [ Click here for your FREE OpenBB Download ]
