Old 30-12-2005, 00:22   #51
Drives: Corsa Sport 20XE
anymore thoughts really need to get this sorted out.
aritchie is offline   Reply With Quote
Old 30-12-2005, 01:00   #52
Drives: admin up the wall
Veering has to be an imbalance, stuck calliper etc! I had a sticking front on my old GTE and it was dangerous! Jump on the brakes and 1 side didnt work so the car pulled badly and nearly went sideways!
You can't moderate me, I am far too important!
wayne451 is online now   Reply With Quote
Old 30-12-2005, 09:48   #53
Drives: cali se4
Originally Posted by RAMBIRKETT
As said before. The rear passenger may be the furthest when looking at the car but when you get underneath and follow the brake pipes you'll soon see which one is furthest away
it is best to do it in this order i will explain why shortly.
rear passenger
drivers passenger
passenger front
drivers front
this is because the master cylinder is split into two circuits the passenger front and the drivers rear is one circuit and the drivers front and the passenger rear is another curcuit. it has been done this way because if the master cylinder does go down it will work two of your brakes still on opposite corners. i have worked on cars that have had a dodgy master cylinder and they have been driving for ages because the brake pedal was soft but it still worked and didnt make that much difference to the way the car stopped all that happened was the car had 50% less stopping power ie only work two opposite wheel's.
daveb948576 is offline   Reply With Quote
Old 10-01-2006, 15:06   #54
Drives: BMW E36 320 Coupe
rear passenger
drivers passenger
passenger front
drivers front
common sense tells me this is the correct way. especially with the reasoning behind it
just want to say thanks for advice as i am very shortly upgrading to astra gte brakes on the corsa. all advise taken on board
namkeaps is offline   Reply With Quote
Old 10-01-2006, 16:57   #55
Drives: Corsa 2.0 16v Sport
Just a quick thought.
My brakes on my Corsa Sport were pulling to one side.
It was the rear bias valve coming in too much as the car was lowered. Slackened this off to nothing, fitted V6 fronts.
It's a lot better
Dean_W is offline   Reply With Quote
Members: 43,233
Threads: 310,682
Top Poster: LEE69 (43,151)
