Anyone know where the factory one is on a mk3?
Think summot has gone on mines so want to check all the wiring on it.
ta![]()
ta![]()
mines behind the passenger side footwell trim on the left. its 2 little box things.
Think its part of the Siemens alarm unit - but don't that get chucked out when a clifford is fitted?
not any need for a 'brain' really, just a master solenoid, and slaves. - so they might not be one at all?
arse, better have a look tonight then i guess![]()
i'm sure the black box is behind the drivers side kick panel, in the space behind the ecu.with the panel off, push the drivers door button down and listen for the click from the box in the footwell area and as i think it is behind the ecu.
On my Cally turbo i have a grey module a bit fatter and a bit narrower than a ciggy packet it has the word KIEKERT written very boldly on it this is defo the central locking module on the cally it is by the ECU which is in the drivers footwell behind the paneling that covers the wing
Phase 4 nearly done Phase 5 here I come :)
