Idling problem
Results 1 to 23 of 23
Thread: Idling problem
    Jun 2004
    Edinburgh
    MK3 Astra Cabrio
    Idling problem
    My revs keep going from just under 1000 revs to just under 2000 revs when im stopped at lights etc. Happens most of the time
    Took it to a few garages to get it looked at but they wouldnt touch it as its supercharged.
    Anybody know of anything it could be? Just so can ask a garage to check that part see if its at fault
    Thanks!
    Car is running sweet apart from that, super fast now
    MIGClub Member CortraGTE's Avatar
    Jul 2005
    The South West
    XE Nova
    Any ECU warning lights on?
    Sep 2004
    Glasgow
    phase 2 astra GSI
    Air leak?
    Lamba sesnor? remember this happening on my corsa replaced the lambda and it was sorted!
    £30 odd quid for one at Halfrauds!
    Phase 2 astra GSI ;)
    Jun 2004
    Edinburgh
    MK3 Astra Cabrio
    No lights on
    When got a new driveshaft fitted today he had a quick look for air leaks couldnt see much but didnt want to check everything coz knows nothing about the kind of engine.
    How do I check the lamba sensor Dean? Remember this going on forshalls corsa once before
    Sep 2004
    Glasgow
    phase 2 astra GSI
    Try another one!!
    You must know someone with same car you could try theirs!
    Jul 2005
    The South West
    XE Nova
    1. Attach a oscilloscope or DVM to the OS switching wire. The connector end would be the best place to monitor this point. Put the ground probe to a good earth point on the car (i.e. chassis).
    2. Increase the engine speed between 2500 and 3000 RPM for 3 minutes. This allows the OS to heat up and light the CAT.
    3. Allow the engine to fast idle and check for OS switching. The OS voltage should switch high and low from 200mV to 800mV at a very fast rate, typically between 8 to 10 times a second (or 1 Hz).
    4. The oscilloscope will be able to see this transition taking place. But a DVM will only see the average switching voltage (RMS) and will only show about 450mV. A sluggish OS may appear to be functioning correctly and may not revel the voltage being high. If the DVM has a MAX and MIN function, the range of average switching will be more easily spotted.
    - eh ok then probably easier to just try a different one lol
    Jun 2004
    Edinburgh
    MK3 Astra Cabrio
    Quote Originally Posted by deano-corsa
    Try another one!!
    Nope dont know anyone else with a supercharged corsa
    Would it have to be a 1.6 16v astra engine it comes out of to try it?
    Jul 2005
    The South West
    XE Nova
    Would be the same LS anyway I think they are a fairly universal application but im not 100% just any 1.6 should do it
    Jun 2004
    Edinburgh
    MK3 Astra Cabrio
    So I could try any vauxhall one?
    My pal works in Halfords and has an xe might ask him to try one for me or his one!
    Sep 2004
    Glasgow
    phase 2 astra GSI
    karen they are pretty universal..
    thought yours was a C16XE
    it WAS an X16XE at one point (astra engine) and was converted to a back to a corsa GSI engine
    find a 1.6 16valve vaux engine and get the lambda off them
    Jul 2005
    The South West
    XE Nova
    If he works in Halfords just get him to "borrow" one for you they should stock them (well they did in my days there but that was a wee while ago and its gone downhill since i left lol) try it and take it back if its not that
    Jun 2004
    Edinburgh
    MK3 Astra Cabrio
    Na was a gsi and now is an astra engine!
    Will speak to Niall later on and see what he can do for me regarding a lamda from his work
    Anything else it might be if its not that though?
    Sep 2004
    Glasgow
    phase 2 astra GSI
    Aye, it could be ur gommy feet hitting the accelerator instead of sitting on the brake in traffic lmao
    Jun 2004
    Edinburgh
    MK3 Astra Cabrio
    I actually put the handbrake on instead of keeping my foot on the brake
    Jul 2005
    The South West
    XE Nova
    Would have said its got to be some kind of sensor its got to be either too much/little fuel/air right? Try the CTS too mine did something similar recently was idling funny and they eventually started jumping about turned out it was the CTS (eventually got an ECU light which aided in solving the problem) it was just a bit minging cleaned it up and had no probs since
    Jun 2004
    Edinburgh
    MK3 Astra Cabrio
    Does it make a difference that I have a MF2 fitted?
    Got asked about that on another site if I had any other management system
    Jul 2005
    The South West
    XE Nova
    From a web site thats sells them - The MF2 is based on an open-architecture design, which means that the unit is freely re-programmable at any time, open to any one who possesses a small screwdriver: no computer interface is necessary! - So it could be the screw has moved not sure though, anyone want to clafiy this?
    full info here http://www.aquamist.co.uk/cp/mf2/mf2.html if anyone wants
    Nov 2005
    leicester
    corsa
    my 20XE does this aswell but only in traffic, i just put it down to engine pulling in hot air! be nice to find a problem tho cuz is well anoying. all the pensioners look at me at the lights thinking i want a rev up lmao
    2 of us could be pleased here people.
    Sep 2003
    cumbria
    bmw 330d, corsa turbo
    the xe in my old corsa did it, was a coolant temp sender. no light or code, just chaged it as it looked a bit corroded and the wiring looked a bit dead.
    re-wried, new cts ran, and still does, on the money
    http://www.youtube.com/user/1muppetsport
    http://www.facebook.com/pages/1Muppetsport/125016194265586?sk=wall
    Aug 2002
    fife
    99 vectra gsi v6
    karen you'll never believe this but i have 2 lambda sensors and 2
    cts's lol
    Sep 2003
    cumbria
    id belive him, ive seen his spare and random parts cupboard......
    Jul 2005
    The South West
    XE Nova
    Curson24 mine did the same just cleaned the CTS (the connections were minging and so was the probe) it was fine after that. You should give it a try mine didnt show any fault codes for ages then one day it did so i quickly grabbed a paper clip and it was shouting Coolant Temp Sensor reading high voltage. Not had any problems since. Worth a shot anyway.
    Jun 2004
    Edinburgh
    MK3 Astra Cabrio
    Quote Originally Posted by starkie
    cts's lol
    Why didnt u tell me on wednesday when I was up at yours
