Ok got all the rocker off last night and sorted that out. On the test run I found I was getting a squeal from the lower front of the car only at low speeds 3-5 mph and when turning at low speed. Its not in time with the engine so could this be a wheel bearing. Does not make any noises at higher speeds. Any ideas??
what you mean the calipers sticking on the disks? would that make a squealing sound? what would you suggest give em a slap with a rubber mallet or something?
best get myself outside with a can of brake cleaner then, i'm hoping it is the brakes that'll be alot cheaper than a wheel bearing. Cheers.
