help with fault code 117 wastegate valve low voltage if im correct
i was reversing last night and hit a high kerb and smacked my exhaust pretty hard.
since then the turbo seems to be making alot louder sound,lots of vibrations through the car and i just had the 117 fault code flash up
this is wastegate valve low voltage if im correct
any ideas how to cure this fault code or why the turbo seems to be making so much more noise?
thanks
thanks
