Old 23-11-2005, 09:08   #1
Drives: N/A
Wastegate chatter?
What is it and why am i getting it? it sounds similar to my mates dump valve,
ive heard its no good thing and if so what is causing it?
/\STR/\ is offline   Reply With Quote
Old 23-11-2005, 09:22   #2
windowlickeruk's Avatar
i am also getting it but i think the recirculation valve on mine may be blocked but if its not i dont know whats causing it.
if you look at my thread on this page tathan explains all
windowlickeruk is offline   Reply With Quote
Old 23-11-2005, 09:30   #3
Drives: Like its stolen
YOU ARE NOT GETTING WASTEGATE CHATTER YOUR CLUELESS SHOWER OF BAR5TARDS
Hope that helps
chip is offline   Reply With Quote
Old 23-11-2005, 09:32   #4
Hope that helps
thats briliant mate
Old 23-11-2005, 09:40   #5
Glad i was of assistance
The noise you are hearing is NOT wategate chatter, if your penny valve was rattling back and forwards making a noise like that it would fall straight off!
The noise is actually the sound of boost making its way back across the blades of the compressor side of the turbo, it sounds much like blowing onto a desk fan.
Its possibly a sign that your dumpvalve isnt operating properly (the build in recirc one if you dont have an external one) as that should be relieving the pressure and stopping this from happening.
On some turbos it can damage the turbo more or less instantly, on others its fine, on others it will wear it out quicker but not break it quickly.
T3 = last forever doing this
K16 = wear quicker but basically be ok
GT35 = instant death more or less
Old 23-11-2005, 09:49   #6
get your point
clueless=yes
bast/\rd=probably
thank you for your wisdom
Old 23-11-2005, 10:23   #7
Not as clueless now as your were before your post though, hence why MIG is cool
Old 23-11-2005, 10:34   #8
Drives: MK3 GSi TURBO
i have a DV26 fitted and when running boost above 5 PSI i still get compressor stall before the dump valve opens.. DV is clean and brand new do i need to take a spacer out~? if i do short changes with foot no where near the floor its fine u just get DV psssshhh but higher revs/more loads. you here compressor stall before DV!! any ideas??
cheers
nutsaboutastras is offline   Reply With Quote
Old 23-11-2005, 10:34   #9
Drives: N/A
ahhh thanks for clearing that up
another question, if i get an external dump valve, which im going to anyway, will that stop air going back through the blades?
also what the standard turbo on a LET? T3?
cheers
Old 23-11-2005, 10:38   #10
Standard LET turbo = K16 mate
nutsaboutastras, if its only happening under 5psi, it will be a pretty mild amount of stall, so i wouldnt worry about it on a K16 personally.
Old 23-11-2005, 10:38   #11
Drives: me bitch hard !!
cheers
Yeah that will help stop stall but the standard one should also be fine at low boost levels ??
Standard turbo on the C'let is a KKK K16. Smaller than a T3 I'm afraid
artfulmatt is offline   Reply With Quote
Old 23-11-2005, 10:54   #12
im running phase 2 software.. and it does not happen under 5psi it happens over it which is why im worried...
Old 23-11-2005, 10:56   #13
Sorry, bit of confusion here, is that what happens:
under 5 psi, let off throttle hard = no noise
under 5 psi, let off throttle gentley = no noise
over 5 psi, let off throttle hard = dump valve operates
over 5 psi, let off throttle gentley = turbo stall noise
Is that right?
Old 23-11-2005, 11:10   #14
under 5 psi let off hard just= DV
Under 5 psi let off gently= just DV
Over 5 psi let off hard= turbo stall then DV
Over 5 psi let off gently= turbo stall then DV
Old 23-11-2005, 11:34   #15
no problem
no problem
potentially a bit of an issue, how long do you get the turbo stall noise for though?
no problem
Old 23-11-2005, 11:54   #16
about a second i would guess then you get dv ppssshhhh
Old 23-11-2005, 12:29   #17
1 second of turbo stall isnt going to have any significant effect.
If you weaken the DV so it opeates sooner then it will potentially lead to itrunning rich and spluttering when you let off the throttle (air flow meter + atmospheric dump valve = bad idea)
Old 23-11-2005, 12:51   #18
ok so leave it alone then!!
Old 23-11-2005, 13:09   #19
Regional Co-ordinator
CraigGreen's Avatar
Drives: smallblock Novas
Compressor chop..?
Old 23-11-2005, 13:15   #20
Originally Posted by CraigGreen
Compressor chop..?
another acceptable name for it
Old 06-10-2008, 16:06   #21
Drives: ASTRA GSI 93'
Re: Wastegate chatter?
am havin this trouble as well had 3 sets of rebuild on my k16 the smoke is unreal again now a no it is the compressor stall that is frying the oil rings but i would love to know how to get rid of the compressor stall so it stops costin me so much money
RRRachael_GSi is offline   Reply With Quote
Members: 42,347
Threads: 307,090
Top Poster: LEE69 (42,841)
Welcome to our newest member, pippen33pl
