Will drivin a car with power steerin pipes connected hurt the rack....
Results 1 to 15 of 15
Thread: Will drivin a car with power steerin pipes connected hurt the rack....
    Jun 2002
    Nr Maidstone Kent
    Mk3 astra gsi
    Does anyone know if it will damage the rack.
    Fabia Vrs
    Gagged
    Jan 2005
    Poole
    BMW M3 Ltd Ed
    No as it is designed this way.
    Jun 2002
    Nr Maidstone Kent
    Mk3 astra gsi
    So running a power steered rack without power steering pipes on the pump wont cause it any damage.
    Fabia Vrs
    Oct 2001
    london se/kent
    WOMEN WILD.
    hi mate not to sure if that is feasible coz theys are slightly different! Im guessing it wub be like trying to turn thr wheel of a power steered model with the engine off!
    vectra b z20let.
    Cav diplomat auto, the workhorse!!
    Mar 2004
    sunderland
    94 cav turbo
    it would be ok for a short distance but prolonged use may well damage the seals in the rack.
    the steering will be mighty heavy though abit lighter on the move but sill heavy
    another problem is the pas pump will pump fluid all over when the engine is running of if theres no fluid in the system it will damage the pump
    Gagged
    Jan 2005
    Poole
    BMW M3 Ltd Ed
    Mates cossy leaked it's pas fluid all over my drive, so took the belt off. It was not funny driving it like this lmao
    Jan 2002
    Bradford
    a Crotch Rocket
    Quote Originally Posted by stereorob
    No but driving with the disconnected will.
    Gagged
    Jan 2005
    Poole
    BMW M3 Ltd Ed
    Quote Originally Posted by SimonT
    Thank You
    May 2004
    Kent
    Meriva 1.7CDTi 54reg
    remove the belt to the pump and that will be ok
    very heavy steering not worth it unless its an emergency
    Mar 2004
    sunderland
    94 cav turbo
    what car is it. what else does the belt run, alternater, water pump etc
    Jan 2002
    Bradford
    a Crotch Rocket
    It doesn't matter if you remove drive to the pump. The rack itself is designed to work with fluid circulating through it. If there is no fluid it will be damaged.
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    the pump will deffo be foooked without fluid in it if run.
    They're there, in their room.
    Jan 2002
    Bradford
    a Crotch Rocket
    True. I think i the way i worded it sounds like i'm saying the pump will be fine, which of course it won't.
    Jun 2002
    Nr Maidstone Kent
    Mk3 astra gsi
    I just got the problem of gettin the old xel pas pipes to fit the xe pump, their too long.
    Fabia Vrs
    Jul 2004
    Midlands, Northants
    Astra GSI Turbo
    fact.
    Running pump with no fluid will feck it.
    Turning the wheels without fluid going through it will feck the seals after time, if it dont damage your arms before hand.
    I wouldnt run it without fluid and pump running at all, aint worth it, racks arnt nice to replace.
