MFD MPG Sensor?!?!
Results 1 to 4 of 4
Thread: MFD MPG Sensor?!?!
    Sep 2004
    Glasgow
    phase 2 astra GSI
    MFD MPG Sensor?!?!
    I asked this before but dunno where it went to..
    I have a mk3 astra GSI which is currently running a LET and F20box..
    my mfd is reading 99.9mpg permanently.. how can i get this sorted out? where is the sensor?
    does it work with the LET???
    MIGWeb User Gsi_Joe's Avatar
    Jan 2005
    North Lancashire
    Astra Gsi 16v
    im not sure if this will help but when i got my gsi the speedo was faulty so i got a new one fitted. Now this new one had was a different motronic mk or something so my mpg etc was reading 99.9mpg. Anyway the bloke to see is on here and he's called ian, cant remember owt else sorry! just do a search for mfd programming or something and im sure he'l help ya out!
    If everything's under control, you're not going fast enough!
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    The speed sensor is on the back of the clocks - its output is via the blue/red cable that goes to the MFD.
    You'll also need to connect up the injector pulse signal from the ECU to the MFD but being a different engine you'll probably find it reads incorrectly.
    UK
    Cav turbo and XJR
    yes connect the red/white or brown/black wire (which even one you find) in the drivers footwell, between the ecu and car loom.
