Simtec70 ECU heat fault
Results 1 to 6 of 6
Thread: Simtec70 ECU heat fault
    Droitwich
    Wonder if anyone has/had the same problem with Simtec70 ECU on 1998 onwards Astra G X18XE1 engine?
    After engine warms up the ECU light comes on with code 0201 (believe Injector 1 code) then runs like on 3 cylinders. (swapped injectors and always 0201)
    When engine cools it is then OK but still has the stored code.
    Cold engine plus pre-heated ECU to 70 deg c (over!) = instant fault.
    Hot engine with fault plus freezer cooled ECU (approx 10 mins) = instant clear.
    Moved ECU from block and goes forever as long as you don't stop when the heat rises and eventually faults.
    Can't find any fault code info on Simtec 70 in usual places - any help appreciated.
    Can anyone confirm this ECU resets it's learnt map (not codes) with power off for say 1hour?
    Cheers,
    Pete
    Droitwich
    Thread Starter
    New ECU fixed problem but still would like info ref fault codes for Simtec 70?
    Topbuzz etc doesn't seem to list this version.
    Any pointers much appreciated..
    Dec 2001
    Chelmsford, Essex,
    Astra1.8, Zaf1.8/1.9CDTI
    P0100 Mass Air Flow Sensor Voltage High C-09
    P0100 Mass Air Flow Sensor Voltage Low C-09
    P0110 Intake Air Temperature Voltage High C-08
    P0110 Intake Air Temperature Voltage Low C-08
    P0115 Coolant Temperature Voltage High C-07
    P0115 Coolant Temperature Voltage Low C-07
    P0115 Coolant Temperature Wrong Signal C-07
    P0120 Throttle Position Sensor (TPS) Voltage High C-06
    P0120 Throttle Position Sensor (TPS) Voltage Low C-06
    P0130 O2 Sensor Circuit Voltage High C-26
    P0130 O2 Sensor Circuit Voltage Low C-26
    P0131 O2 Sensor Range/Performance C-26
    P0135 O2 Sensor Heating Voltage High C-25
    P0135 O2 Sensor Heating Voltage Low C-25
    P0170 O2 Sensor Rich Exhaust C-26
    P0170 O2 Sensor Lean Exhaust C-26
    P0201 Injector Valve 1 Voltage High C-18
    P0201 Injector Valve 1 Voltage Low C-18
    P0201 Injector Valve 1 Open Circuit C-18
    P0202 Injector Valve 2 Voltage High C-19
    P0202 Injector Valve 2 Voltage Low C-19
    P0202 Injector Valve 2 Open Circuit C-19
    P0203 Injector Valve 3 Voltage High C-20
    P0203 Injector Valve 3 Voltage Low C-20
    P0203 Injector Valve 3 Open Circuit C-20
    P0204 Injector Valve 4 Voltage High C-21
    P0204 Injector Valve 4 Voltage Low C-21
    P0204 Injector Valve 4 Open Circuit C-21
    P0230 Fuel Pump Relay Voltage High C-05
    P0230 Fuel Pump Relay Open Circuit C-05
    P0325 Knock Signal No Signal C-22
    P0335 Crankshaft Sensor Open Circuit C-04
    P0335 Incorrect RPM Signal C-04
    P0340 Camshaft Sensor Incorrect Signal C-11
    P0351 Ignition malfunction cyl.1 C-14
    P0352 Ignition Malfunction Cyl.2 C-15
    P0353 Ignition Malfunction cyl. 3 C-16
    P0354 Ignition Malfunction cyl. 4 C-17
    P0403 Exhaust Gas Recirculation (EGR) Valve Voltage High C-23
    P0403 Exhaust Gas Recirculation (EGR) Valve Voltage Low C-23
    P0403 EGR Valve Open Circuit C-23
    P0443 Fuel Tank Ventilation Valve Voltage High C-24
    P0443 Fuel Tank Ventilation Valve Voltage Low C-24
    P0443 Fuel Tank Ventilation Solenoid Open Circuit C-24
    P0480 Relay Low Fan Voltage High C-31
    P0480 Relay Low Fan Open Circuit C-31
    P0481 High Fan Relay Voltage High C-31
    P0481 Relay High Fan Open Circuit C-31
    P0500 Vehicle Speed Sensor Incorrect Signal B-04
    P0505 Idle Air Control Voltage High C-27
    P0505 Idle Air Control Voltage Low C-27
    P0560 Battery Voltage High C-03
    P0560 Battery Voltage Low C-03
    P0602 Control Module Programming Error C-02
    P0650 Check Light Voltage High C-33
    P0650 Check Light Voltage Low C-33
    P1110 Intake Manifold Valve 1 Voltage High C-28
    P1110 Intake Manifold Valve 1 Voltage Low C-28
    P1326 Knock Control Maximum Spark Limit Cylinder 1 C-22
    P1327 Knock Control Maximum Spark Limit Cylinder 2 C-22
    P1328 Knock Control Maximum Spark Limit Cylinder 3 C-22
    P1329 Knock Control Maximum Spark Limit Cylinder 4 C-22
    P1405 Exhaust Gas Recirculation (EGR) Valve Feedback Voltage High C-23
    P1405 Exhaust Gas Recirculation (EGR) Valve Feedback Voltage Low C-23
    P1510 Idle Position Switch Voltage High C-12
    P1510 Idle Position Switch Voltage Low C-12
    P1515 Idle Speed Actuator Feedback Signal high C-27
    P1515 Idle Speed Actuator Feedback Open Circuit C-27
    P1530 A/C Request Line Voltage High Air Conditioning System with Engine Cooling Module B-14
    P1530 A/C Request Line Voltage Low Air Conditioning System with Engine Cooling Module B-14
    P1540 Air Conditioning Pressure Invalid Signal Air Conditioning System with Engine Cooling Module B-13
    P1540 Air Conditioning Compressor Request Signal High Air Conditioning System with Engine Cooling Module B-13
    P1540 Air Conditioning Compressor Request Signal Low Air Conditioning System with Engine Cooling Module B-13
    P1540 Air Condition PWM-Signal invalid Air Conditioning System with Engine Cooling Module B-13
    P1571 Traction Control PWM Invalid Signal B-06
    P1600 Reprogram or Replace Electronic Control Unit (ECU) C-02
    P1610 Immobiliser Function not Programmed Immobiliser B-07
    P1611 Wrong Security Code Entered Immobiliser C-02
    P1612 Immobiliser No Or Wrong Signal Immobiliser C-05
    P1613 Immobiliser No Or Wrong Signal Immobiliser C-05
    P1614 Wrong Transponder Key Immobiliser C-06
    P1813 Torque Control Circuit Incorrect Signal B-05
    P1813 Torque Control Interaction Too Long B-05
  5. Remove Advertisements
    Nov 2002
    Livingston
    sounded like a dry solder joint
  7. #5
    Droitwich
    Thread Starter
    MarkT -- Thanks for the listing - very much appreciated. They seem to have doubled up the high's and lows faults in this version!
    Aragorn -- My thoughts exactly and sent it away via Fuel Parts to get it tested and they didn't heat it up enough and it passed all tests as I know it did when cool!!
    Having opened up the ECU it is all covered in jelly goo and thin film gold wire weld technology. Despite being in electronics I had to give up!
    Cheers both..
  8. #6
    Dec 2001
    Chelmsford, Essex,
    That's TIS for you.
    1 Could means several things.
    You need a Tech2 to read them anyway, and that gives more info.
  1. 07-04-2015, 13:38
  2. 14-01-2012, 23:25
  3. 03-05-2011, 14:36
  4. 26-09-2010, 13:32
  5. 24-09-2010, 21:28
