Corsa C - Washer system not working!
Closed Thread
Results 1 to 23 of 23
Thread: Corsa C - Washer system not working!
    Feb 2005
    Post Corsa C - Washer system not working!
    Hi, First of all I'm new to the site, looks nice
    My bro has a Corsa C shape (latest), 2000 registered, and over the past few days the washer jets no longer work (front nor back). I can't even hear the pump, so am guessing this is the problem.
    Decided to check the fuse (two are listed in the handbook). One is supposed to be 15A, but is a 20A in the car, the other doesn't exist. I am guessing the other is for headlamp washers or something.
    Anyways, there seem to be a few fuses that dont relate to the handbook! :S. Would the wrong rating fuse in there mean the pump could blow if something went wrong? It has always worked before, and should have been set at the factory from new.
    Anyone with a new shape Corsa know where abouts is the washer pump is located and how can i test it?
    Many thanks
    Duncan
    Dec 2004
    Burnley
    Astra GSI
    Welcome to site
    Dont really know about corsa c but i would of thought the motor for the washer wiper would be on the washer bottle or a few wires linking to it....Have a close look
    If the fuse is bigger it should still work..........The fuse is just there as a circuit breaker......mind you if your bowing fuses, bigger than there supposed to be then you gota prob. Check all the fuses in the fuse box
    Aug 2003
    Fareham, HANTS
    Mini Cooper S
    Hi Duncan,
    Glad u followed my advice lol
    ///SOUTH CENTRAL MINCERS
  5. Remove Advertisements
    Feb 2005
    Thread Starter
    Hi, Thanks for the reply/welcome!
    I checked most of the fuses and they are fine. I stopped at the one i removed and all the lights came on, that was a little worrying!!
    I couldnt see much leading from the washer bottle, it's a bit tight behind the bulkhead.. although I'll have another look in the daylight tomorrow!
    Would be nice to test the pump for sure.....
    Thanks
  7. #5
    Feb 2005
    If you have a digital voltmeter, get someone to operate the washers inside the car and measure the voltage across the electrical terminals on the pump at the same time. You should measure 12V DC. If there is a voltage but the pump isn't working then the pump is fercked.
    Oh and welcome by the way. It's a good site - I only joined a couple of weeks back myself.
  8. #6
    Mar 2003
    Manchester
    Corsa C / RWD Nova
    Washer pump fuse is in the fuse box under the bonnet (just in front of the n/s strut top, under the large plastic cover)
    There's a small black plastic cover that covers the top ten fuses
    Remove that and the washer pump fuse is the top middle one !!! (3rd from left)
    From factory is should be a 10 amp mini fuse but vauxhall released a bulletin to main dealers to replace it with a 15 amp one to cure the problem of it blowing !!!!
    Dave
  9. #7
    Feb 2005
    Thread Starter
    Thank you for the quick replies!
    Where abouts is the washer pump?? im guessing it's fairly close to the washer fluid reservoir but i cant find it, and it's dark outside! thought it may be hidden behind the wing or something?
    The 3rd fuse seems to be a 20A in my brother's Corsa.. I think that's it anyways. Fuse seems intact !
  10. #8
    Mar 2003
    Manchester
    Corsa C / RWD Nova
    Are you sure you have removed the small plastic cover (about 2 by 1 inch) and checked the correct fuse ???
    Washer pump is located in the washer bottle - remove the wiring to it and connect a test lamp across the two terminals - if it lights up when you work the washers - the pump is probably f**ked
    Dave
  11. #9
    Aug 2003
    Fareham, HANTS
    Mini Cooper S
    Ah the good ol test lamp...Legendary in fault finding!!!
  12. #10
    Feb 2005
    Thread Starter
    Quote Originally Posted by fearless
    Dave
    Hi,
    The pump is actually IN the washer fluid reservoir??
    So there is a small cover within the main aux fusebox cover? if so, then no i havent removed this one.. was just going by the diagram in the handbook for 'washer...' 3rd fuse from the left, on the 1st row of the main block of fuses...
    will have to go out and have another look for this cover, may contain the correct fuse
    but im guessing its the pump itself, so if i can locate it ill be able to test it for sure
    many thanks!!
  13. #11
    Mar 2003
    Manchester
    Corsa C / RWD Nova
    My moneys on the fuse !!!! - Get loads coming in work at the moment - blown due to water in bottle/pump frozen !!!!
    Dave
  14. #12
    Feb 2005
    Thread Starter
    Dave
    really? well i hope its the fuse as it's much easier to sort! and if that's a valid reason for it blowing, then i wont have to try too hard to find out why it blew!!
    this little cover you are on about, where the washer fuse is below, where abouts is it again mate.. within the main fusebox?
    im loooking at the diagram in the book (as its too cold to go out again), although its not very clear! cant see it shown.....
  15. #13
    Mar 2003
    Manchester
    Corsa C / RWD Nova
    Yeh - in the main fuse box in the engine bay - the main cover hinges up to reveal the fuse box
    The small plastic cover is situated at the top left hand corner of the main fuse box - covering the top 10 fuses
    Dave
  16. #14
    Aug 2003
    Fareham, HANTS
    Mini Cooper S
    What fusebox are you checkin Dunc?
    The one in the car or the one under the bonnet?
    (Im asuming there is one in the car?)
  17. #15
    Feb 2005
    Thread Starter
    Dave: i think ive found the cover in the diagram, i probably missed it!! I was probably taking row 2 as row 1! doh!
    Why is the first row covered?
    That'd explain why the fuses didnt match up with the book if so!! Will have a look tomorrow morning, thanks a lot!
    joey: there's only one mentioned and only one i can find, in the engine bay!!
  18. #16
    Feb 2005
    Thread Starter
    Just looked in the manual at the fuses, the 3rd row, 3rd fuse in = fuse 17 .. the one i was checking (thinking row 2 was row 1!!) is indeed 20A
    So i think you've found the problem mate, i wasnt removing the cover! doh!!
    hopefully the fuse is blown and its not the pump itself, will find out tomorrow
    THANK YOU for your help
  19. #17
    Feb 2005
    Thread Starter
    Thank you very much, that solved the problem!!
  20. #18
    Jul 2002
    Pompey
    Rover 45 MK2 TD
    Are you the DunkyB I am thinking of?
    lmao
    Check out my sheddy Sport!
  21. #19
    Feb 2005
    Thread Starter
    Quote Originally Posted by Rusty 16v
    lmao
    If you are the Rusty with an Astra I'm thinking of, then yeah!
  22. #20
    Aug 2003
    Fareham, HANTS
    Mini Cooper S
    Quote Originally Posted by DunkyB
    Remember you told me about the ignition lights coming on when you pulled a fuse out....which fuse was it? I know you told me before, but that was when you thought it was row 1....??
  23. #21
    Feb 2005
    Thread Starter
    Quote Originally Posted by JoeyB
    it would either have been fuse 4 or 5, i think 4
    which = number plate lamp, or electric window lifters. Well his doesnt have leccy windows!
    Not sure why removing the num plate light fuse would turn on all the lights, lol.
  24. #22
    Feb 2009
    Talking Re: Corsa C - Washer system not working!
    Quote Originally Posted by DunkyB View Post
    Having spent 2 whole days off trying to find how to fix this exact problem, and having read and re read a Haynes manual (not mentioning the fuse problem) I found this thread, and I really have to say thanks! Fixed the problem in under 2 minutes after reading!
    Thanks guys! Saved me loads of time and money!
  25. #23
    MIGClub Member jamied's Avatar
    May 2003
    northampton
    Astra, Vectra Estate...
    Thread is a few years old mate, can you check before bumping old threads up.
    oh, welcome to MIG.. lmaolmao
Closed Thread
