Why does my ( ! ) light come on when going around corners?
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 34
Thread: Why does my ( ! ) light come on when going around corners?
    OllyHewitt
    Guest
    When giving my car some stick around corners.
    The red ( ! ) light appears on the dash, which is brake fluid resevoir isn't it?
    I topped it right up as I thought it was going out of the sensor when going to one side, but its up to the brim now - and still happens...
    Any gen?
    Nov 2000
    North Ayrshire
    6J Ibiza FR TDi
    sure it aint your oil light?
    VAG history - BLT | CFHD
    Jul 2004
    Edinburgh
    Mk2 Astra -60mm+18"s
    Your just special
    Prevoisly known as - Its NOT a Merit.
  5. Remove Advertisements
    Sep 2004
    Nottingham
    Cars, Loves:Whores
    That's definitely the handbrake on light, or a brake fault light.
    Not sure why it comes on when cornering though, unless some part of the brakes are binding when the suspension loads up
  7. #5
    Jan 2002
    Bradford
    a Crotch Rocket
    If it is the handbrake warning light it's probably a dodgy handbrake switch. I've had that problem before where it flickered on cornering.
  8. #6
    OllyHewitt
    Guest
    nah - my handbrake light is ( P ) and it works fine
  9. #7
    Jul 2002
    Wirral
    RX7 FD3S, MR2, Merc E320
    (!) means you're 'parked'. If you stop your car and put the handbrake on, and I think if you turn the ignition off, you'll get the (!) symbol. It's definately nothing to do with oil though.
    I've got a feeling I'm wrong though.
    2002 - 2015, 19,000 posts - 13 sad years on MIGWEB
  10. #8
    Feb 2002
    Fareham, Hants.
    C20XE 13S Z20LER Z17DTH
    Yes, you are, a Nova definitely isn't clever enough to know if it's moving or not!
    This is the brake fluid low warning light. It works by using a plunger in the lid of the fluid reservior. Maybe when it was last empty it has got stuck a bit low down? Or it's just fooked? Try another cap maybe? Check the brown and brown/ red wired to it aren't broken. Or just unplug it.
    They're there, in their room.
  11. #9
    Dec 2001
    Chelmsford, Essex,
    Astra1.8, Zaf1.8/1.9CDTI
    (!) is brake fluid low level.
    Check the wiring to the float switch
  12. #10
    Feb 2002
    West Yorks
    Vectra 3.2 GSI
    Quote Originally Posted by OllyHewitt
    Any gen?
    corner slower
  13. #11
    Jun 2004
    oxforshire
    cali turbo 92
    brake fluid low
  14. #12
    OllyHewitt
    Guest
    Quote Originally Posted by wazpaz
    corner slower
    lmao lmao lmao lmao thats the funniest thing ive heard you say this year lmao lmao lmao lmao
  15. #13
    Feb 2002
    West Yorks
    Vectra 3.2 GSI
    well on the way to Trax last year i thought you were gonna roll it on that roundabout lmao lmao
  16. #14
    Gal
    Gal is offline
    Sep 2003
    London, United Kingdom,
    There and back
    corner slower
    Dont drive round corners lmao lmao lmao
    My hand to Japs eye co-ordination is great!!!
  17. #15
    OllyHewitt
    Guest
    standard 1.2 suspension, and 185/75/14" tyres didn't help then
  18. #16
    OllyHewitt
    Guest
    i'll try a new cap & sensor
  19. #17
    Middlesex
    sideways
    Quote Originally Posted by Astra Dan
    No, but it know's the hand brake is on, by the switch on the handbrake! lmao The handbrake operates the (!) light
    Brian Sidebotham.
  20. #18
    OllyHewitt
    Guest
    how can it when the ( P ) light comes on when i put the handbrake on
  21. #19
    May 2002
    Chesham, Bucks
    S14
    maybe its wired up wrong? or maybe it wired up right? who knows?
    ///DGOAI
  22. #20
    Oct 2003
    Westhill Aberdeenshire
    Like it's a hire car
    ollys rightm the rest are wrong, the handbrake is deffo the (P) and the (!) as used on some cars for both is only the brake fluid, both came up in my theory test so I checked!!!
  23. #21
    OllyHewitt
    Guest
    lmao nice one bud
  24. #22
    Middlesex
    sideways
    My MR2, and the majority of cars I have seen have (!) as the handbrake... Maybe they are the dashes without a specific (P) light.
    Brian Sidebotham.
  25. #23
    Oct 2003
    yep, al the cars Id been in previously used the same light for both, but the (P) light was in my theory test so i asked, and then chacke the nova and it has both.
  26. #24
    UK
    Cav turbo and XJR
    Have you got two lights then olly ?
    The mk1 bog standard ones only have the 1 light.
  27. #25
    OllyHewitt
    Guest
    I have one ( P ) which is activated by the handbrake
    then a ( ! ) which is occasionally activated by turned a hard right lmao
