Hello....
Im going to look tommrow but.... Just fitted a new (s/h) head on my xel...
Runs fine but it kinda sounds a bit Growly about the top end... (sounds like its comming from the rear cam)..... the head came without cams so i had to use my old ones... No end float, but i didnt check for play... kinda figured they are all the same... no signs of wear (head or cams .... Oh and should the marker numbers on the cam caps face away from the cntr ?........ any ideas !
Thanks again
Steve.
Thanks again
Steve.
