Perished Ventilation Hose? (56k warning)
Results 1 to 6 of 6
Thread: Perished Ventilation Hose? (56k warning)
    Sam
    Sam is offline
    Dec 2002
    Worcestershire
    1995 Calibra V6
    Ever since last friday when I bought my Astra, I have noticed that when the engine is warm, there is this kind of oily smell in the cabin coming through the air vents on the dash.
    Decided tonight to take off the spark plug cover thing and do a bit of investigation, I think I have found the cause of the problem:
    The part number on the hose is 90529869, which EPC lists as a Ventilation Hose - Cylinder Head Cover to Air Cleaner Elbow Hose (hose marked in green on the diagram):
    Seeing as the area where the leads are on the cylinder head bit and the front passenger side corner of the engine block is covered in a sort of dried on oil, am I to assume this is the cause of the oily smell in the cabin?
    Sorry for the pic quality - taken on my phone earlier tonight with my trusty torch...
    Engine is X14XE in a 97/P reg mk3 Astra by the way.
    Nov 2002
    Livingston
    Re: Perished Ventilation Hose? (56k warning)
    yer mines open to atmo on my c16xe and i get oily fumes now and then
    funny i saw a bloke with a astra 1.4 16v in halfords last week with identical problem - hoses mustnt be rated for oil use
    Sam
    Sam is offline
    Dec 2002
    Worcestershire
    1995 Calibra V6
    Thread Starter
    Yeah! I remember when I had a Corsa B with the X12XE engine (1.2 16v) the same hose on that engine used to get clogged up with crap was kind of an off yellow colour substance then eventually I had to replace the hose as it started to get all squidgy for want of a better word, no doubt if I left it, it would have had the same fate as the hose on my Astra!
    Well I will pick up a new hose from Vauxhall on saturday, today I'm getting a timing belt kit and fan belt fitted by a local garage! My poor wallet! lmao
  5. Remove Advertisements
    Sam
    Sam is offline
    Dec 2002
    Worcestershire
    1995 Calibra V6
    Thread Starter
    Changed the hose today, and no more oily smell inside the car! Yay!
    Some more pics:
  7. #5
    Jun 2004
    Guernsey
    Astra GTE Turbo 8v
    thats 1 nasty pipe. needs a clean dont u think? lmao
  8. #6
    Sam
    Sam is offline
    Dec 2002
    Worcestershire
    1995 Calibra V6
    Thread Starter
    Yeah I changed the hose earlier tonight but tomorrow at some point I will give it a good clean! It's all down the side of the engine too, looks like it's been like that for ages and the previous owner couldn't be bothered to sort it?
