24-07-2004, 11:02
#1 | | MIGWeb User
Join Date: Feb 2003 Location: northampton Drives: nova xe/astravan
| advice on rotor thickness ive been offered some bells and rotors to go with my brembos i got a while back. the brembo will take up to 30mm thick discs, would it be ok to use 22mm discs with them, as ive been offered some smart hi-spec bells and rotors but they are from a big discs kit which uses standard calipers, my worry is they are too narrow and will cause braking problems/be unsafe, any gen would be cool cheers guys |
24-07-2004, 13:04
#2 | | MIGWeb User
Join Date: Dec 2001 Location: Chelmsford, Essex, Drives: 3.0 V6, 2.5 V6, 1.8
| Re: advice on rotor thickness Vaux standard vented are 24mm, minimum thickness 21mm.
You need to check with the manufacturer what the minimum thickness is, if it's not stamped on the disc rim.
__________________ [url=http://77.96.230.10/sytemsandsoftwaredevelopment/systems.htm] How Tos
The two most life changing experiences you'll ever have. Finding Jesus, and having a baby. |
24-07-2004, 16:33
#3 | | MIGWeb User
| Re: advice on rotor thickness cheers mark |
24-07-2004, 16:49
#4 | | MIGWeb User
Join Date: Feb 2003 Location: ruislip Drives: nova 1.8 16v on tbs
| Re: advice on rotor thickness as long as they are bigger than 22mm they'll be fine, no less though, or the pistons copuld pop out when the pads are worn right down, changine them at about 3/4 of the way through the pad negates this though obviously
__________________ shonkyopels.de making shonky opels awesome again
Scuderia Ferrari, World constructors champions Formula 1 2008 |
24-07-2004, 16:59
#5 | | MIGWeb User
| Re: advice on rotor thickness cool, might have them then, should look good, they have anodised gold bells, think the rotors are near enough new anyway, but 22mm thick sounded quuite thin for front rotors?, probably becuse they are from a big disc kit that uses standard calipers? |
Members: 43,232
Threads: 310,682
Top Poster: LEE69 (43,151) | | Welcome to our newest member, hayden222 | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
