Old 24-07-2004, 09:22   #1
Drives: Astra Sport
Fault Code Question
If I bridge a & b on the diagnostic plug with just the ignition on I get 3 12's and 3 31's. If I do it with the engine running I just get 12's.
12 is no rpm (crank sensor) signal.
Does that mean it has stored that code but isn't having that problem at the moment?
Surely no crank sensor signal would have a major effect on the cars running!
I disconnected the ecu for about half an hour and I still get 31.
The car runs fine, although isn't holding more than 0.95 bar.....
Miles is offline   Reply With Quote
Old 24-07-2004, 09:24   #2
Admin
Tom Williams's Avatar
Drives: Vectra Derv Wagon
Re: Fault Code Question
12 is the initiation of diagnostics, 31 is no crank sensor and cos the eingine not running it flashes up
I now do not run Private Messaging on MIG.
Please email me at - tom@migweb.co.uk.
If you're query is regarding part of the website please use the helpdesk
Tom Williams is offline   Reply With Quote
Old 24-07-2004, 09:30   #3
Drives: Astra Sport
Cheers Tom, no problems there then
Members: 43,233
Threads: 310,683
Top Poster: LEE69 (43,151)
