Closed Thread
Old 08-07-2004, 16:56   #1
Drives: Astra estate 1.6 16v
2.0 8v nova conversion
im in the middle of doin one at the moment. Im having trouble seperating the cv joints from the driveshafts. have split the pin but cant seem to seperate it. also i think i mite have a few problems wen it comes to the wiring how hard is this im transplanting into a 1.4sr btw so there is fuel pump etc but i have one sorted.
cheers
Im not a boyracer i just race them!
JimmyFlo is offline
Old 08-07-2004, 17:01   #2
Banned
Drives: A Nissan and a Vaux
Re: 2.0 8v nova conversion
when in doubt...
Grab an angle grinder
Vaux Crayzee is offline
Old 08-07-2004, 17:02   #3
erm im trying to make 2.0 driveshafts out of mkII cav and nova gte ones so that wouldnt really help
JimmyFlo is offline
Old 08-07-2004, 17:07   #4
Banned
bahh.. spoilsport
Old 08-07-2004, 17:11   #5
Administrator
Astra Dan's Avatar
Drives: 1.3L GTE 16V SXi Est
You have to spread the circlip in the CV and keep it spread. Then give the CV a light tap with a mallet to persuade it to fall off.
BTW, uploader.co.uk has gone offline
Click for info: GTE16V Mk2 SXi Estate
Astra Dan is offline
Old 08-07-2004, 17:13   #6
oh yeah forgot about that. cheers for the help. if i have any probs withn the loom and ecu is there any1 near north wales who knows what theyre doing and is in need of a crate or two of beer?
JimmyFlo is offline
Old 08-07-2004, 17:16   #7
Administrator
Astra Dan's Avatar
Wiring is a peice of cake.
Brown/ yellow or brown/ blue = fault light depending on age of engine.
Brown/ white = ground this to flash codes.
Black = ignition feed, connect to the black near the coil is best.
Green = tacho feed, again, there's a convnient one near the coil.
Red = +ve, straight to battery.
Red/ blue = fuel pump. Connect to the fat terminal on the pump, via a 20A fuse. Ground the other side to the chassis somewhere.
All the rest you can just tape up.
Old 08-07-2004, 17:20   #8
dint think it was that simple. wot fuel pumps do u guys use wen u do your conversions?
JimmyFlo is offline
Old 08-07-2004, 17:24   #9
Administrator
Astra Dan's Avatar
Any external one will do fine. My 20XE Nova runs on a 1.6 GTE pump, jubilee clipped to the rear chassis. As long as you're not running loony power it's fine. You'll need an injection tank, too ideally.
Old 08-07-2004, 17:26   #10
back to the wiring again sorry. so all i have to do is plug the ecu in and all the sensors etc then make the connections u told me and thats it?? can i use my sr ignition coil etc then?
JimmyFlo is offline
Old 08-07-2004, 18:02   #11
Administrator
Astra Dan's Avatar
No, you'll have to use the coil that matches the engines.
But yes, plug all in and make those connections and away she goes.
Old 08-07-2004, 18:05   #12
cheers for your help dan much obliged.
JimmyFlo is offline
Old 08-07-2004, 20:30   #13
Drives: tigra
cheers for that dan as its me doing the wiring 2moro and jimmy was finding out for me while i was at work!!!
nova girl is offline
Old 08-07-2004, 20:34   #14
Administrator
Astra Dan's Avatar
Aha! It's easy, troost me.
Old 19-11-2008, 20:42   #15
hi
i am looking for some info i have a nova gte, i am looking at putting a 2.0 8v in it with twin 40s, can you tell me how to do this, and if i use the 2 ltr brakes do i have to turn them down or not and just use the gte shafts with the 2ltr cv
thnx
paul
yzf250crazy is offline
Old 21-11-2008, 11:20   #16
Administrator
Astra Dan's Avatar
Use the search function please.
Closed Thread
Members: 43,233
Threads: 310,682
Top Poster: LEE69 (43,151)
