how do i check if a ball joint is worn?
Results 1 to 5 of 5
Thread: how do i check if a ball joint is worn?
    Apr 2004
    hello!
    can anyone tell me how do i check a ball joint to see if it's worn and needs replacing?? - i'm talking about the front lower joint on the hub - and what are the symptons of a worn joint?
    vaux tigra '97
    thankx!
    Northeast Kent
    Re: how do i check if a ball joint is worn?
    it will dislocate
    May 2002
    Ammanford, S. Wales
    Monterey 3.1 Diamond
    lol
    rubber boot should split
    also the balljoint may be very stiff to move
    Gagged
    Sep 2002
    wiltshire
    astra 888 nova xe
    jack up the car so the whels of the ground grasp the wheel at 12 and 6 o clock and shake it if theres movment get some on have a look at the ball joint if its worn then you will see it moveing.
    if you hold the wheel at 3 and 9 and shacke it and there movment have a look at the track rod end. if theres movment in bot possably wheel bearing.
    thats how they are tested on an mot. if the rubber boots are split the joint may still be ok.
    worn ball joins go losse not stiff.
    stt
    stt is offline
    Mar 2003
    Taunton
    Audi RS6
    with the car jacked up, put a bar between the wishbone and the hub and see if you can induce any movement whilst trying to prise it apart, if theres movement it needs replacing
