MK3 Dash into MK2 Astra
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 29
Thread: MK3 Dash into MK2 Astra
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    I know a couple of you have done this.
    What did you do with the heating?
    I've blanked 1 of the Screen vent outlets on the heater box, and the cold air outlet.
    So my Centre Vents will now be for show only.
    Has anyone managed to keep the centre vents? or better still got temperature controlled air from them?
    I'm thinking I could unblank the spare screen vent outlet and maybe route that round and hook up the centre vents?
    Scotland
    Saab/Pug/Zaf
    wrong vent to block, now the drivers screen wont clear
    Dec 2001
    Chelmsford, Essex,
    Quote Originally Posted by 16vastra
    The MK3 Dash Vent chamber is common the whole length of the dash, so that one is spare.
    Scotland
    Saab/Pug/Zaf
    ah right, weird...probably why mk3s mist up lol
    ask pete r and haynzee if you dare cos they did petes mk3 dash
    Dec 2001
    Chelmsford, Essex,
    I asked Haynzee about dash fitting before, but he'd forgot what they did.
    The MK3 Dash does have two vent connections, just you don't need both, so I blanked the one that was awkward to get at.
    The MK2 has a separate chamber for either side.
    Scotland
    Saab/Pug/Zaf
    lol sounds about right
    my dash is cut in half, i only clear the drivers side just now, dont know the mk3 setup, just thought it was the same as mk2
    Dec 2001
    Chelmsford, Essex,
    I made the mistake first of all, cutting the dash where it fouled the GTE dash mount on the steering wheel bracket.
    Glued that back in when I realised why it was hollow!!
    Chiselled off the bracket then!!
    I was hoping the MK3 Dash would mount like the MK2, but as soon as I took the MK2 one out.. Oh Fook, that aint the same!!
    Still the main dash is in, albeit secured at either side only at the moment.
    Just hoping the Centre Console etc. will fit OK!
    Mar 2004
    gte16v
    heh this is funny i just did my astra3 to astra 2 dash swop, il post some pics later.
    The Uberdruck GTE 16V
    jonix :I don't know if I should be rebuilding it or ragging the nuts off it.
    Mar 2004
    gte16v
    what dya think, did this a couple of weeks ago, not plumbed in with heaters
    yet and onle one speed on the heater speed , why!? same connection bar 1 wire proble have to use original 3 speed switch rather than 4, i also get an airbag too. lol lmao
    Jul 2000
    from what i remember, it fitted reasonably easily, drill new holes in the bulkhead and bolt it in, as per the mk3, the heaters i just left set to "hot" and piped them so the screen got the hot air
    if he's too hot he can open the window
    BRB
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    And what, exactly, is wrong with the Mk2 dash?
    They're there, in their room.
    Mar 2004
    gte16v
    it looks like an old arcade machine lol
    Aug 2000
    Paisley,Glasgow
    Astra 1.6 16V,A
    Mark T, what is that digi dash from?is it out an old Senator or something
    Mar 2003
    HERTFORDSHIRE
    Astra Thurlby T9
    mark, are you using the mk3 heater box and blowers or just the mk2?
    MIGClub Member Spankee's Avatar
    Jul 2000
    Braintree, Essex
    GTE/Mondeo
    You cant use the mrk3 blowers box you have to mod the mrk2 item...the dash is fairly easy to fit only hard parts are getting heater system. controls all the the electric switchs straight forward ...
    Dec 2001
    Chelmsford, Essex,
    MK3 Heater box was an option but you'd need to redrill the bulk head at least.
    Someone has done it, either here or cavweb.
    Dunno why your fan doesn't work properly, mine works fine (4 position so 4 is wired to 3 as well)
    Dash is a Senator Item yes.
    I wanted a Black Dash to bin the Tobacco brown Original, MK3 was easier to find.
    My Heater will work as Original I hope!!, not fitted the Heater panel yet.
    Jul 2000
    Braintree, Essex
    GTE/Mondeo
    Was the Senator digi dash a straight forward swap if not what mods..did you have to do..
    Oct 2003
    west london
    yellow cally se2
    what digi dash is that?
    if your girlfriend expects you to go down on one knee you better make sure she goes down on both regually
    **s/s manifold wanted for cav/cally xe pm me**
    Oct 2003
    west london
    yellow cally se2
    dont worrie didnt scroll down far enough lol
    Dec 2001
    Chelmsford, Essex,
    had another look at the bulkheads mounts, and although I've drilled holes the bolts don't reach into the engine bay!
    Dash wasn't straight forward.
    Here's a How To so far: http://82.34.51.160/sytemsandsoftwar...torLCDDash.htm
    Mar 2003
    HERTFORDSHIRE
    Astra Thurlby T9
    a mate abt 5 years ago put a mk3 dash into his v6 mk2 van. hes a wizzard with a welder and he welded the mk3 bulkhead section (where the hole is) into his mk2 and then used all the mk3 heaters. he did say for a temp measure he used half the heater box of a mk2 and the other from mk3 and mated the 2 together.
    jit
    jit is offline
    Sep 2003
    Leicester
    Celica GT4 - 225BHP
    Quote Originally Posted by Mark T
    mark,
    how did you get past the above problem???
    cheers
    No Signature Allowed
    Dec 2001
    Chelmsford, Essex,
    Quote Originally Posted by jit
    mark,
    cheers
    I just drilled new holes in the dash for the side mounts, and with the Bulkhead studs in the drilled holes it held in very securely.
    I have issues with the Centre console now though.
    The angle where it should join the dash is very different to that of the dash, so it looks like I've pulled in the bottom of the dash too far.
    But if I let the bottom out, then big gaps appear between the sides of the dash and the A pillars.
    Not looked too much into the centre console since.
    May need cutting down to sit lower on the exhaust tunnel.
    The Clio Seats I've fitted sit rather close to the handbrake which makes me think the the floor pan is narrower on the MK2 than the MK3. so I might not even be able to fit the centre console at all.
    We'll see.......
    jit
    jit is offline
    Sep 2003
    Leicester
    Celica GT4 - 225BHP
    ta mate
    nice one mate
    appreciate the guidance...
    midway through attempting mine, ive got the 8v so floor pan maybe slightly different to the 16v GTE for the centre console...
    any further gen, then please let me know...
    regards
    Jit
  26. #25
    Mar 2003
    HERTFORDSHIRE
    Astra Thurlby T9
    Jit, you will have problems with the centre console then. ive got a 8v cabbie and hated the 8v centre consoles (where the tape holders sit). i managed to get a 16v console to fit eventually with alot of f*cking around, modifying gear stick and adjusting the gear linkage to stop gearstick hitting the console whilst putting it in 2nd and 4th! the position of the mark 3 consoles will be similar to to the mk2 16v consoles as the gear linkage runs inside the car where as the 8 valvers sit underneath.
    i really want to do a mk3 conversion to finish the car off and i cant get all the bits i need for £30 but i am really unsure on the heater situation. how did you get on mark with that mark? ive a feeling that the heater box in the 8v is prob diff from the 16v
