Ohm's resistance?????
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 48
Thread: Ohm's resistance?????
    nrj
    nrj is offline
    Nov 2002
    Hampshire
    Not a Vxl
    anyone know what it should be for a 1.4 8v MPi astra mk3 m/94 crankshaft sensor?
    also are all the 8v sensors the same, ie same part no????
    CAR FOR SALE: Vauxhall Zafira
    BREAKING: Yellow Pug 306 Convertible
    WANTED: Downhill Mountain Bike
    Northeast Kent
    teh correct way to test the sensor is too hook up a metre switched to AC volts and crank the engine. you should get spikes up to 5 volts.
    nrj
    nrj is offline
    Nov 2002
    Hampshire
    Not a Vxl
    Thread Starter
    Yer that way will tell me if the into to the sensor is ok, but not if the sensor itself is down.
  5. Remove Advertisements
    Mar 2002
    Leicestershire
    no vauxhall
    If you've got access to some electrical test equipment, you'll need an oscilloscope and a differnetial probe (photo):
    This is what the waveform looks like:
    The sine wave gives the ECU the RPM signal and the large SPIKE tells the ECU it's position, hence it being called a CAS (Crank angle sensor). the spike is caused by the un-toothed part of the toothed disk.
    Happy testing, Scott
    www.scottbouch.com
    Snowy_astra: best sex you can get is from a woman
  7. #5
    Middlesex
    sideways
    lol, you could have triggered it a bit better!
    Brian Sidebotham.
  8. #6
    Mar 2001
    London
    Audi S4 Biturbo
    I want a scope.
    I miss twidling with them and looking like I know what I'm doing.
  9. #7
    Mar 2002
    Leicestershire
    no vauxhall
    did it that way on purpose to see it in the middle of the screen!
    But just for you Brian S, a nicely triggered one!
    lmao
    www.scottbouch.com
  10. #8
    Middlesex
    sideways
    Wahey!
    I have a Gould DSO too
    Chris, keep an eye out on Ebay, they come up very cheap nowaday's
    Brian Sidebotham.
  11. #9
    Mar 2002
    Leicestershire
    no vauxhall
    This one was 40 notes a few years back, it now a little worse for wear as it lived a few feet away from one of my Tannoy 15" dual concentrics for a while... I didn't think at the time how poweful the magnet could be. Now the right hand side ot the trace rises, while the lefthand side is fine!! Bugger.
    I want my FLUKE digital one back that i used to work with... but i haven't got 3k to spare.
    www.scottbouch.com
  12. #10
    Jun 2000
    Swindon
    here are some waveforms I took of the sensor output on my 20XE :
    http://homepage.ntlworld.com/retro.s...1_cranking.jpg
    http://homepage.ntlworld.com/retro.s...2_cranking.jpg
    http://homepage.ntlworld.com/retro.spect1/cs2_idle.jpg
    cs1 is the later plastic type, cs2 is the metal version.
    people say the metal version is better - and it is - see how it outputs a much stronger signal.
    also notice how the signal strength increases with rpm.
  13. #11
    Scotland
    Saab/Pug/Zaf
    good god
  14. #12
    Jun 2000
    Swindon
    that's a tektronix TDS360 scope btw, if we're talking scopes - has a floppy drive built in - very useful!
  15. #13
    Mar 2002
    Leicestershire
    no vauxhall
    used one at my last place which had a printer built in, and 4 channels, all in different colours! RS232 link to a pc etc...
    That cost a small mortgage!
    www.scottbouch.com
  16. #14
    Mar 2001
    London
    Audi S4 Biturbo
    Gary the show off.
    Work were throwing out a pair of HP digitizing scopes (200MHz beasties) in a lab clearout. But some helpful bugger said they should be given to another dept that does transport design.
  17. #15
    Scotland
    Saab/Pug/Zaf
    wtf just try another sensor instead of zapping it with some glorified 1950's tv. they only about 30 quid from autovaux (the sensor, not the crappy looking tv lol)
  18. #16
    Mar 2002
    Leicestershire
    no vauxhall
    Quote Originally Posted by Gary
    Thats some difference between the plastic and metal ones!!!
    The voltage wil go into the 100's given some welly! must be a clever input circuit in the ECU to read small values and also cope with the massive voltages!
    www.scottbouch.com
  19. #17
    Mar 2001
    London
    Audi S4 Biturbo
    Quote Originally Posted by sb_scottmonkey
    I believe the ADC works simply on the 0v cross, everything else is dumped.
  20. #18
    Mar 2001
    London
    Audi S4 Biturbo
    Quote Originally Posted by 16vastra
    Isn't she a beaut...
  21. #19
    Mar 2002
    Leicestershire
    no vauxhall
    But it's got to pick out the angle spike... although i suppose that just wouldn't give anything at that time, as it's not crossing zero for a few "cycles" it just notices the blank patch rather than the spike it'self!
    www.scottbouch.com
  22. #20
    Jun 2000
    Swindon
    I'm very lucky as I work in the eng. test dept of our company.. and sooner or later equipment is replaced or obsoleted
    I won't mention the other bits I have then or the electronerd talk in this thread will be short circuited by drool
    glorified 1950s TV lmao
  23. #21
    Mar 2002
    Leicestershire
    no vauxhall
    OMG! that thing'll steralise you!!!!
    www.scottbouch.com
  24. #22
    Jun 2000
    Swindon
    yes - most ECUs use the same zero crossing detector, a dedicated little IC I forget the name of.
    I was mucking around with mine as I though the CAS signal was the problem.
    it turns out that this was:
    http://homepage.ntlworld.com/retro.spect1/12v_noise.jpg
    it was screwing up the ECU above about 5.5k rpm.. causing it to see roughly half the true rpm - amazing the engine wasn't leaned out to self destruction really.
  25. #23
    Mar 2002
    Leicestershire
    no vauxhall
    We used to have fun playing football with 1KV charged electrolytics!... but of course we'd solder longer legs to it beforehand!!
    Would give a nice crack if you hot it in the goal (steel cabinet!!)
    www.scottbouch.com
  26. #24
    Mar 2002
    Leicestershire
    no vauxhall
    what was causing the noise?
    www.scottbouch.com
  27. #25
    Mar 2001
    London
    Audi S4 Biturbo
    The little mouse that lives in the dash turning his kettle on.
