Where can I buy a cheap used engine oil burner?
Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 69
Thread: Where can I buy a cheap used engine oil burner?
    Sep 2004
    Nottingham M1 J26
    911. Loves: Dirty sluts.
    As title really, just something to heat the garage
    MIGWeb Moderator
    Midlands
    Nowt
    Re: Where can I buy a cheap used engine oil burner?
    Mine was a grand new a few weeks back
    Look on ebay, but prices will be silly really
    Jul 2002
    Leamington Spa
    Nissan Fairlady Z / JTin
    I've got a knackered old XE?
    MSG
    MSG is offline
    MIGClub Member MSG's Avatar
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    make one yourself, just dip in several big wicks and light it up. and stuff the black soot.....compost your garden with it.!
    Sep 2004
    Nottingham M1 J26
    Exactly don't really fancy paying a grand
    Why are the so expensive?
    Quote Originally Posted by MSG View Post
    And poison myself probably!
    Quote Originally Posted by Violet View Post
    lmao
    MIGWeb Moderator
    Midlands
    Nowt
    Pass as to why they are expensive
    Wrong time of year to look for one second really
    Jul 2002
    Leamington Spa
    Why not get one of those 'camping gaz' heaters for the time being? I had one, they're really good at heating a garage and are cheap.
    MIGWeb Moderator
    Midlands
    Nowt
    How big is the garage Nemesis?
    Sep 2004
    Nottingham M1 J26
    It's a large double, plus a workshop upstairs
    Not a bad idea cheers
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    If its for keeping you warm, have a look at the halogen / infrared type of heaters as they tend to heat objects rather than the air around them.
    Pointless heating large areas of cold air in a draughty garage.
    The best alternative is a split airconditioning unit which can provide heat a lot more efficiently and cheaply than an electric / gas one. They will keep you warm in the winter, cool in the summer and have the advantage of being able to dehumidify as well.
    Sep 2004
    Nottingham M1 J26
    Quote Originally Posted by Dom View Post
    Not a bad idea
    I just assumed that anything to do with heating would be expensive to run for a few hours a day, whereas I've got plenty of waste oil to burn
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    If I read some of the specs right on the semi decent split air conditioners, you can get 7Kw of heat out for 2.5Kw of electricity in.
    Could be totally wrong as its been a while since I dabbled in the aircon market but well worth investigating.
    Sep 2004
    Nottingham M1 J26
    Thanks I'll take a look
    TBH might do the whole house seeing how bad gas prices are lol
    Sep 2006
    M1 J28
    knock one of these up - doesn't look too hard
    http://journeytoforever.org/biofuel_...rth/z/woh1.jpg
    MIGWeb Moderator
    Midlands
    Nowt
    Best thing to do would be 'tap' your electricity meter and just leave some electric heaters on*
    *Idea not MIG approved
    Jul 2009
    Tyne & Wear
    Corsa SRI Z20LEH, B X14XE
    Just skipped thruough the thread asap, but im +1 on hali/infrared heaters, i have 2 fitted on the garage walls, about 1200w each..... they definetly heat you more then the air, i can feel them burning me if i stay in its light too long! mine give out a lot of heat too after been on a while... theres a noticable difference from outside!
    And yep the thing on the aircon is correct, i have a 2.4kw cooling unit which supplys 6.8-7kw of heat when the pump is reversed........ your just aircon'ing the world really though and using the pumps heat.
    If your garage is pretty well sealed you might prefer the aircon way, it will regulate a set tempurate, where as the hali heaters for something drafty as they stay on all of the time
    Halogen heaters is guna be the cheapest upfront cost though
    Dec 2007
    Nuneaton
    A carbed xe'd reno kangoo
    make one, look at turk burner on youtube, use a gas canister its easy.
    Vectra B Estate 2.2
    Vectra B Saloon 2.6
    MIGClub Member elongmoss's Avatar
    Jun 2011
    Burton-on-Trent
    3L V6 Mk4 Astra
    Make one +1
    use an oil boiler internals like below
    Worcester Dansmoor Oil Boiler Burner and Control Box | eBay
    mount it and have it blowing into the garage 50/50 mix engine oil and parrafin will work a treat
    or it will explode destroying you and the garage
    If at first you dont succeed... CHEAT!
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Quote Originally Posted by wkdkris View Post
    lol, no your not. The refridgerant makes the heat either way, running it in heating just means its dumping the heat made by condensing the gas in the room rather than outside as it would do to cool the room
    Jul 2009
    Tyne & Wear
    Quote Originally Posted by Frisco View Post
    is that why the air going outside is ICE cold.... and the pumps run in REVERSE...... few hints there
    it doesnt dump COLD and WARM air in to the room, just the heat. exhuasts the chilled <<< so you are airconing the world
    .... though and using the pumps heat.
    i did say it pushes in the heat from the pump
    best idea yet!
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    MIGWeb Moderator
    Midlands
    Nowt
    I'm lost with this air con thing.
    MSG - help us out here?
    Sep 2011
    Bedford
    MK2 astra gte
    Yes make one!
    heat by ben a.k.a me, on Flickr
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Very simple. Two coils one inside and one outside.
    Changing the refridgerant from a liquid to a gas makes one coil hot and one cold. The controller on the wall lets you choose which coil does what.
    No pump being used to heat anything.
  26. #25
    Jul 2009
    Tyne & Wear
    No pump being used heating anything.
    the refridgerant pump!!!! duh
