Got my new batteries but need some help .
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 27
Thread: Got my new batteries but need some help .
    Dec 2002
    Essex
    Lada Riva
    New batteries turned up today but have some questions .
    The wires look like they plug into the battery but will they come out again ?
    They look like a very tight fit .
    Removed the battery holders on the outside of the chassis and the pack fits ok , need to trim the battery stay to clear the wires .
    Next question .... will my old helicopter charger be ok ?
    It's 2 cell and 7.4v
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Re: Got my new batteries but need some help .
    I'd have thought those battery leads would plug all the way in - how deep are the holes in relation to the cable ?
    Dec 2002
    Essex
    Lada Riva
    Yes , they go all the way in but will they come out again is the thing .... don't want to force them in yet .
    The bit round the outside must compress together a lot to fit in the hole .
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    I've used similar connectors which have had an angled piece of metal inside the female part which grips like buggery - it goes in but won't come back out - you'll only know when you're ready to try though.
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    If you're really worried about them, bung a bit of hot melt glue on it.
    Dec 2002
    Essex
    Lada Riva
    Well they look like they compress as they go in . Don't want to get it wrong .
    MIGClub Member wayne451's Avatar
    Jan 2005
    The Internet.
    Mods round the bend...
    They don't look too different to the old corralli (I think that's what they weere called?) connectors that I used to use, they were gold plated jobbies that slotted into gold plated tubes that you had to solder onto the end of the stick/saddle pack.
    I assume that little wiring harness that you have pictured came with it and adapts your existing wiring or something?
    WTF is that yellow wire about? Not a 'hot wire' for a servo is it?
    Warren Buffett.
    Dec 2002
    Essex
    Lada Riva
    The yellow wire goes in the middle of the pack and the white plug goes into the charger .
    The red and black wires just go onto the speed controller with my Traxxs plug .
    The speed controller has got power capacitors standard .
    Jan 2005
    The Internet.
    Whats the yellow do though? Is it some sort of an earth or something?
    Bugger me all this stuff has changed since I last raced. lmao
    Warren Buffett.
    Dec 2002
    Essex
    Lada Riva
    That's the thing , this is the first Lipos I have bought , will have a look about on one of the rc car sites .
    Jan 2005
    The Internet.
    Just to give me a heads up, who is your car manufactured by?
    I could wager a guess off my old theories off the dog bones and the lower arms but...
    Warren Buffett.
    Dec 2002
    Essex
    Lada Riva
    The good old dog bone method still works well , have got spare diffs , some are locked .. so I can run them with both front and rear diffs locked .
    Can do donuts on the spot until tyres go and no part of the drivetrain has been replaced .
    Shouldn't say that ..... going to break now .
    The make is Hsp but converted them to brushless etc .
    pie
    pie is offline
    May 2009
    blackwood
    Cavalier GSI 4x4
    the yellow lead is so you can balance charger the 2 cells in the lipo
    and ya the push in there only 4mm corallays
    there look the same as my lipos (i post a pic)
    lipos have a safe cut off so they dont blow up ( thye will if they drop below a sectain voltage) check youtube
    pie
    pie is offline
    May 2009
    blackwood
    Cavalier GSI 4x4
    brca lipos
    and big 5200 45c lipos for messing round lol
    Dec 2002
    Essex
    Lada Riva
    Thanks Pie , I'll give them a good push in the hole .
    Have got a voltage cut off on the Ezrun
    No probs with my old helicopter charger then ? the one in the pic .
    pie
    pie is offline
    May 2009
    blackwood
    Cavalier GSI 4x4
    cant see why not fella its a 2cell lipo charger and your lipos are 2cell ya?
    Dec 2002
    Essex
    Lada Riva
    Yes , I like your gold packs
    What sort of life do Lipos have ?
    Can you just top them up like the Ni-Mh and not worry about fully discharging ?
    Pushed the connectors in no problem , just need to solder some plugs on now , it's good that you can change them over .
    One car is Deans and one car is Traxxs .
    pie
    pie is offline
    May 2009
    blackwood
    Cavalier GSI 4x4
    ya just top them up fella
    my gold packs are last year ones
    you can leave them charged and the dont drop voltage like the old nimh packs
    if you got the lipo cut off your fine then no booms for you lol
    Dec 2002
    Essex
    Lada Riva
    Can't find my solder , will let you know how it goes
    pie
    pie is offline
    May 2009
    blackwood
    Cavalier GSI 4x4
    koo
    Dec 2002
    Essex
    Lada Riva
    Decided to ditch the Traxxs plugs and just do everything with Deans plugs .
    Lipos charged , plugs soldered so ready for a test drive .
    pie
    pie is offline
    May 2009
    blackwood
    Cavalier GSI 4x4
    you should notice how quick the brushless setup is now fella
    Dec 2002
    Essex
    Lada Riva
    Glad you came on , hold up ,
    Had a test run today and was set on 3.0v per cell , now the car had about 15 mins use and the voltage cut came in .
    The Lipo was nowhere near hot but was a bit warm .
    Thinking maybe changing the gearing ?
    Got a choice :
    58T Main cog / 26T motor cog < current gearing .
    64T Main cog / 29T motor cog < sposed to be uprated gearing .
    pie
    pie is offline
    May 2009
    blackwood
    Cavalier GSI 4x4
    try uprated gearing fella and see how it goes
    also depends on your driving style...are you flat out on the throttle every or are you on n off etc
  26. #25
    Dec 2002
    Essex
    Lada Riva
    Bit of both realy , over car park , getting used to them but need better charger , mine takes bout 5 hours .
