advice / help needed on garage electrics
Page 2 of 2 FirstFirst 1 2
Results 26 to 50 of 50
Thread: advice / help needed on garage electrics
  1. #26
    Jun 2010
    aberdeenshire
    escort van :P
    Re: advice / help needed on garage electrics
    Quote Originally Posted by Dom View Post
    How are you measuring it ? Peak to peak or RMS ?
    A 230v RMS supply will give you around 320v peak to peak
    A "theoretical" single device (i.e. a theoretical heater) that draws 12kw at 230v will take around 52 amps. If however you plug this into a 284v RMS supply then it will take up to 14.8kw.
    Plugging this value in to the cable calculator comes up with 16mm2 cable so I'd go that way to be on the safe side and limit the maximum total value of your appliances to 12kw (when rated at 230v).
    i didnt get half of that haha. i think the most that wil be being used will be the lift, 32A and some lights, sterio, heater (diesel so dosent use much electric). so i will se about teh price of 10 and 16 mm, and see what i can aford lol
    May 2003
    Belgium
    '90 opel omega
    Quote Originally Posted by bunnymofo View Post
    Whats a TN-S powergrid ?
    Where the powercompany supplies 3-phase power + neutral, with the neutral earthed at the local transformator (starpoint = neutral), and where you have to "make" your own earth by either a loop under your house or cupper sticks hammered into the ground.
    I don't quite understand your values, I thought UK had standard 230V supply (neutral + phase)?
    That would either mean 3x230V transformators (delta grid) without neutral (but you can't have 110V then) or a 3x400V (star) grid with neutral, but you can't measure 260-280V in either case!
    But that's not that important, what is important is securing your cables correctly (right amps breakers), which calculates from the voltage you have available, and securing your personal safety with the device I mentioned before (which is also very important!).
    Note: the above may or may not be entirely correct.
    I wondered why the frisbee was getting bigger, and then it struck me.
  4. #28
    MSG
    MSG is online now
    MIGClub Member MSG's Avatar
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    You can always run seperate circuits (wiring) for each heavy appliance, so won't have to go and buy a real thick wire to supply the entire load, that will not only cost a lot but difficult to hadle and terminate and all wiring should be preferabley conduited, so from your house distributer board run seperate cables supplying power to your lift, seperate for mains ring, seperate for welder, and eperate for lighting, this will also avoid any lights dimming considerably when you switch on heavy loads due to surges.
    The fact is there is a duty cycle to consider, so for example a lift would not undually heat the cable since it will only ever be on for what two minutes maximum to raise the lift, like wise a welder would be not welding co0nstantly for more than a few minutes at a time, the most annoying thing would be lights dimming each time you press the weledr trigger.
  5. #29
    Jun 2010
    aberdeenshire
    escort van :P
    Quote Originally Posted by king nero View Post
    sorry, bit i didnt get half of that either lmao
  6. #30
    Jun 2010
    aberdeenshire
    escort van :P
    Quote Originally Posted by MSG View Post
    i will see how many spare slots there in my consumer unit in the house, and price the cable to do ti seperate, and to wire it all in one big cable. i dont mind the lights dimming when i use the welder, and anyway, when i welt it dims the lights in the house and everywhere else anyway lmao
  7. #31
    MSG
    MSG is online now
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    You should also be aware that using a common RCD in the single supply feed to the garage is not a good idea as upon a fault on any appliance or wiring can suddenly trip the RCD and you could loose all power everywhere including lighting as well as leaving you in dark to work your way out, and you could trip on your trolly jack, bang your head on the lift or trod on your workshop cat and accidently kick your pet dog's bolloxes, so I would highly reccomend seperate feeds each seperately proteceted using indepenedent RCD's as this will give you complete independence, so if you get a fault on one circuit you won't loose power on others. Use a second distribution switch board for the workshop distribution.
  8. #32
    Jun 2010
    aberdeenshire
    escort van :P
    so, if u supply it with a single breaker in the house, then go to a consumer unit in the garage with seperate ones, and just have 13A sockets with built in rcd. instead of a main one, will that be ok ?
  9. #33
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    MSG actually spoke some common sense there .......
    I work in a workshop which is built inside my garage. There are 2 doors to get out of and no natural lighting.
    I was working on a project which involved some pretty industrial electronics and two pieces of kit didn't behave themselves and tripped the main house breaker. Not only did I get a minor zap from it, a quick flash before my eyes but all the electrics and lighting in the workshop/garage went off. I had to feel my way to the main doors to get back to the house to reset the main breaker.
    I have an app on my phone now which doubles as a torch as well as torches in strategic places around the workshop lmao
  10. #34
    Jun 2010
    aberdeenshire
    escort van :P
    ahh, lmao i might just put in a coupple of emergency lights then, so that of te opwer dose go off i can still see but, i have a mini torch on my keyring anyway
  11. #35
    MSG
    MSG is online now
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    Sorry to come back to this a little late, yes that will work fine, since the rcd will only trip your socket circuit and not the others.
  12. #36
    Jun 2010
    aberdeenshire
    escort van :P
    ahh, ok, thanks
  13. #37
    Jun 2010
    aberdeenshire
    escort van :P
    so, wheres the best / cheapest place to buy 10mm T&E ?
  14. #38
    MSG
    MSG is online now
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    Search around for best prices mate, people like WF (wholesale fittings) who supply bulk of wiring and switch gear to the electrical contractors can do a great deals, even possible to buy cheaper on ebay but not sure of the quality may be por if the cable has been imported from certain countries known to produce impure copper cables, this includes China and India, so best to buy British manufactured cable.
  15. #39
    Jun 2010
    aberdeenshire
    escort van :P
    ahh ok, thanks. i will try WF and cpc. i looked in b&q but they only have 25 meters and i need 30 yes, i will stick to british made, i will also try carbootsale. see if i can get a half roll or something.
  16. #40
    MSG
    MSG is online now
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    I think due to the nature of this cable, it is sold either in drums of 25m or 100m, so you will have plenty left over if you went and bought a full 100m reel, not sure if anyone does a 50m reel. I am sure any an electrical retailer might offer you a better price for 30m as they sell per meter so it is a question of asking and them having enough on their drum.
  17. #41
    Jun 2010
    aberdeenshire
    escort van :P
    ahh, thats not good lol. i thaught i would be able to get a 50 M roll i have a roll with a little bit left on, im going to look at it and see what it says, i will post it up in a minute
  18. #42
    Jun 2010
    aberdeenshire
    escort van :P
    the one ihave is a 50 meter reel. but tere not enough on it so il have to look for more.
  19. #43
    MSG
    MSG is online now
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    RS Components do a 50m reel of T&E in both 10mm and 16mm, £134 and £203 respectively plus VAT.
    check their website, you can orrder using your card if you are not an account customer. Cables | Electrical/Power | Ring Main and Lighting Cables 4294954854&selectAttribute=10.0mm²#breadCrumb
  20. #44
    Jun 2010
    aberdeenshire
    escort van :P
    thanks, il have a look
  21. #45
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Try a normal electrical wholesale place mate, RS are generally expensive
  22. #46
    Jun 2010
    aberdeenshire
    escort van :P
    Quote Originally Posted by Frisco View Post
    ok. thanks
  23. #47
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    If you've got 30m of wiring to do and its going to run outside then seriously consider buying SWA (armoured cable). Normal cable will degrade in sunlight and there is the chance of chopping through it by accident.
  24. #48
    Jun 2010
    aberdeenshire
    escort van :P
    i have thaught of that, but its even more expensive, so, i am going to run the T&E inside alkathene piping. and most of it will be under the ground, none of it will be in the sunlight
  25. #49
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    30m of 16mm 2 core SWA comes in at around £120 inc VAT - pretty bombproof stuff as well.
    https://www.electriccableco.com/electric-cable-shop.htm
    * That may not be the best price but doesn't seem too bad from what I paid for mine ages ago
  26. #50
    Jun 2010
    aberdeenshire
    escort van :P
    ahh, thats not so bad
