Results 1 to 2 of 2
Thread: Anyone in the Northeast that could help with an engine conversion??
    Apr 2010
    Right, i have a 51 plate corsa which had piston slap
    So instead of deciding to drop the same z14xe engine in, i decided to put a z18xe in, again from a prefacelift corsa..
    Got everything out of the other car that was needed..
    Full car wiring harness
    dials
    ecu
    transponder
    chip in the key
    bcm
    Eventually got everything in the car ready to start, turns over but no spark and no fuel with EML flashing..
    These are the fault codes i have:
    0539
    0649
    2198
    2197
    1514
    1515
    1616 P1616 Wrong Vehicle ID from Instrument Control Module C-40
    8359
    1512
    1613 P1613 Immobiliser No Or Wrong Signal Immobiliser C-05
    Would appreciate it so much if anyone could help.
    Will pay if anyone can sort it
    Cheers
    Jamie
    Nov 2006
    Newcastle (ish)
    Cavalier 1.8 LS
    Re: Anyone in the Northeast that could help with an engine conversion??
    sounds like the code isn't registering from the key. maybe need to swap some wiring around. I suggest getting a haynes manual and doing some reading to see if the wiring pairs up.
