Results 1 to 7 of 7
Thread: Cracked B pillar - Who can fix it?
    May 2009
    Newcastle
    Nova XE
    Question Cracked B pillar - Who can fix it?
    I've got a Corsa B and the driver side B pillar is starting to crack. I want it to get treated asap before it gets worse.
    Is there a place in the north east who have experience doing this sort of work that you guys can reccomend?
    I'm based in Newcastle but willing to travel if its a decent place.
    Cheers
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    Re: Cracked B pillar - Who can fix it?
    any bodyshop should be able to repair it, although I don't believe there is a permanent fix for this it just goes with corsa ownership.
    May 2009
    Newcastle
    Nova XE
    Going to Vauxhall on Wednesday to give me a quote.
    Nov 2006
    Newcastle (ish)
    Cavalier 1.8 LS
    Where's it cracked? Pictures?
    Plenty of body shops in the area that will be able to do it for you, but you'll probably find that a local engineering or fabrication place will do the job for you if you are prepared to tidy it up after wards.
    May 2009
    Newcastle
    Nova XE
    I don't mind getting it fixed somewhere and then take it somewhere else to take care of the paint work.
    Jul 2008
    Stanley
    Corsa B
    Sure i read that a plate needs to be welded from the inside,i may be wrong but sure i rear it somewhere.
    Nov 2006
    Newcastle (ish)
    Cavalier 1.8 LS
    How did you get on with this anyhow?
